ccscott49
Also to smooooooth the seam, use a cut potato, sikaflex doesnt stick to them.
impressed!Also to smooooooth the seam, use a cut potato, sikaflex doesnt stick to them.
impressed!
still I'd really like to know HOW you found this out![]()
One very important trick is never to apply the Sika ( Or anny ather chaulking ) with decending temperatures. . . . . Onley apply with constant or decending temperature.
I did a prof Sikaflex course.
impressed!
The Sika apply course guy said “ min seam width 6 mm” A long elastic stretches better than a short one. Logic ain´t it?
not necessarily as in order to get the longer stretches, you shouldn't go very deep as it flexes less and it wont accomodate expansion very well. So overall it should be more or less the same (in theory at least)Also uses more Sikaflex![]()
I am also just embarking on a deck job, have already replaced 300 plugs, removing the bronze screws, with bit and brace type screwdriver, deepening the holes with 1/2" countersink and replugging, every screw came out, some damage to a few, which I replaced with like. Now its caulking and groove deepening (in some places) I use a rotozip, with a wood guide, bent to follow the grooves and a 3mm cutter. It will be fun in Corfu!
Hi all
i've been looking into how to recaulk my teak deck and i've seen videos and forum posts where people recommend placing tape in the bottom of the groove
"Most seams are 6mm wide, you need to then apply bond breaker tape (choose 4mm for a 6mm gap as it is a sod to get in place). The bond breaker tape is to allow for movement as the Sika is designed to adhere to two surfaces only."
the thing is, according to the sika website here
https://dnk.sika.com/dms/getdocument...ak_Decking.pdf
it doesn't say anything about taping the bottom of the slot
any thoughts? thanks
If you dont want to sand, you masking tape up the seams.
I use a plastic or silicone kitchen spatula to sweep along the fresh caulking which beds it in firmly (don’t be too sparing with the caulking) and gives a nice smooth finish flush with the tape such that I haven’t needed to sand afterwards.
Do you need to wet the spatula before doing that?
Great info and tips on this thread and I'll be visiting the Boatpaint site - thanks Chris.
However when you remove old caulking (at least on my yacht) there is no bond tape at the bottom of the seam that would I guess have been applied originally - so what's that all about then ? I note that some makes of caulking do not appear top require bond tape.
