Caladh
Tranona - in some parts on the deck the caulking is effectively "free" in the groove and just pulls out. There is def no existing tape.
Sounds like it has lost adhesion to the adjacent planks. Assuming the deck is glued down it seems reasonable to clean up, prime and fill.
Acids may have the effect of softening the caulking in the seams of our panels and the resulting softening will lead to seam failure over a period of time. Once a crack opens between the seam and the wood, it allows cleaning solutions to collect in the cracks where it cannot be easily rinsed out, and seam failure accelerates.
The "cleaning" action of acids appears to be very effective, because the acid actually removes some of the material being cleaned—in our case, the wood and the caulking. Over time, enough material may be removed to compromise the integrity of the wood where it meets the caulking seam, causing a crack, which, as described above, accelerates the failure of the adhesion of the caulk to wood.
Even with care, in time the surface of the wood will become uneven. When this happens, the deck should be lightly sanded with a sanding machine to smooth the surface. This will actually increase the life of the deck by exposing less wood to the elements and preventing the grain from trapping dirt or air-borne corrosives.
TranonaThge use of bond tape depends on the method of construction, thickness of teak and type of caulking used. The purpose is to only allow bonding to the edges of adjacent planks to accommodate movement of the planks if they are not firmly attached to the substrate. Thick, wide planks screwed to the substrate clearly have the potential to move more than thin narrow ones glued down with no fastenings.
So there is no universal "must use tape" rule, although with some caulking it is essential to clean and prime the seams to ensure the caulk adheres fully.
If there is no sign of tape when the old caulking is removed, nor signs of caulking breaking away from the sides in otherwise sound seams then it is reasonable not to use tape in the replacement.
In the past I've posted a link to Teak Decking Systems advice re (acid) cleaners. Obviously TDS are trying to promote their own range of products (caulk, adhesives & cleaners) but their advice might be worth considering by owners of teak-decked boats
Interestingly, regarding onward maintenance of teak decks they make this point.
Sounds a little counter-intuitive but I can see some logic to this.
I used TDS caulking on my after deck, it was the best decision I made. I used a caulking that was haft the price of TDC on the coachroof and I had to tape everywhere, took hours. With TDS I could lightly sand after without taping.. brilliant��
Although my teak is right as rain, the Sikaflex between the panels is tired in some places, and non-existent in others.
I´ve bought the relevant Sikaflex to fill the gaps, but before starting I was wondering if anyone had any helpful tips /advice.
Electric tape to protect the teak and a confident squeeze to get the continuous line are my 2 main thoughts...
Justin
Well my advice is best to just rip it all out an replace with Flexiteek.
You will spend hour taking out the old sikalfex, then adding primer, laying the new sikaflex, then sanding it down. And in a few years you will have melting sikalfex, black smudges on your clothes, and will have to do it again. Just bite the bullet and buy Flexiteek - totally excellent product with no downsides.
