Quandary
My saga of Isotherm calorifier problems continue. I now have one issue left, anyone got any ideas.
The calorifier is back in the boat with a new gasket and no leaks from the tank itself, BUT-------
The hot water outlet has a very slow drip, about one drop every 15 seconds when the system is fully pressurized, it stops when the taps are run to reduce the pressure a bit . The 15 mm stainless steel outlet pipe emerges from the tank insulation and the brass temperature mixer is connected to it with a copper compression ring on the very short pipe stub. The compression nut has been screwed up to the end of the thread on the body of the mixer where it can go no further. The pipe stub is too short to be cut to allow a new compression ring to be fitted. It is such a simple problem but looks as if it will cost me a new calorifier, (I have the boat up for sale and intend not to land a new owner with any latent defects)
Before I order a new calorifier, is there any way that this leak could be permanently cured? tape around the ring, sealant or something else? I know that this sounds like a bodge, but there is absolutely no draw left on the compression nut, the leak is so small but large enough to make a damp patch in the locker. Reducing the system pressure would also solve it but a new owner might expect to use the shower. Or could I grind or file a bit off the threaded nut to allow it to tighten up a bit further, tricky when the nut is trapped on the pipe stub.
If I was not selling I would put up with it, by turning the pump off after every use and keeping the ice cream carton under the drip but fancy trying to justify that to a potential purchaser.
