Tightening a 100mm nut
I'm assuming that the nut is six sided. If so, a plastic nut would be severely stressed by a two sided spanner. Much better to have a six sided spanner to spread the load evenly on the nut. Whether to make the spanner from plywood or steel plate, depends on the abilities of the OP.
Magic.
I really like this idea.
Two bits of steel, offcuts . Two bolts with appropriate nuts, a big tap and a square hole.
I'd stick with mild steel, use HT bolts, available from any hardware store - and keep oiled.
Easy
See post 4 made out of wood for those that couldn't fabricate in metal.
Forgive me asking; I hoped someone else could have asked by now: What skin fitting needs a 100mm lock nut? Seems whopping to me.
I have a supplementary question, what skin fitting relies on the integrity of a plastic nut. I can see that the nut might need to be tightened but not to the point where the nut is destroyed by the forces applied.
Surely the fitting is applied on a bed of Sika (or something similar) and the nut is applied to squeeze out any sealant on the inside of the hull. Once set off the nut might be tightened, slightly to compress the sealant. But the nut is almost, but not quite, decorative. During installation I can see why you might not want to tighten by hand, or your hand will be covered in sealant - but the nut should not need much more than hand tightening. I did tighten slightly using a plumbers spanner - like the red handled device, the 3rd photo in Post 7.
The only large hull fitting I can think of is that of the head - but I doubt its 100mm
Jonathan
Had to do the ply spanner option before on a toilet cistern for work. Cut out with jigsaw. Works a treat.
12mm or thicker should do it. No danger of damaging a plastic nut.
Oil filter strap wrench is an option as well.
Jonathan
Nomenclature has been sadly lacking in this thread. The one in the third photo is generally known, around these parts, as a Swan-Neck Pliers. The other plumber's device, the one with the worm-drive adjustment, would usually be called a "Stilson".
I know what you mean by swan-neck pliers, but they seemed to get rebranded as water pump pliers a while back. Swan-neck is a much better name though.
It's a common thing for somebody of one generation/regional background on site to be screaming "fetch me the effing *insert name here*!" while the other person frantically searches through a toolbox trying to translate. All good fun.
Don't get me started on inches to mm though
Don't come to Oz
If I ask for a Mole wrench .... I'm looked at askance. If I asked for a swan neck pliers I'd get no-where. But if I asked for the grey handled spanner (ours have uniquely in my tool box - grey handles) - I'd have success. I don't know what they call a Stilson here, not much call for one on our cat. My support is my wife and I don't expect here to know the name of every tool necessary - being descriptive is so much more useful and leads to much harmony.
If I ask my children, who live in England, how often they Hoover ...... they look blank.
Some people call an adjustable spanner a shifter
Interscrews are also known as Chicago bolts
And my sister in Vancouver calls her mobile (or mobile phone) a cell phone.
Just be a bit more accomodating as Salt'n'shaken implies.
Jonathan
They are also commonly known as Gland Pliers, ( for doing up gland nuts of various sizes) and these in particular are of the 'slip joint' variety.
When I worked on a DC3 in the States 40 years ago, any adjustable spanner was a "crescent wrench", probably because Crescent was one well known manufacturer of said item, a bit like the "Hoover" thing.
If you want to be pedantic, a Stillson wrench doesn't have worm-drive adjustment, but does have two "L's"
I am reminded of an article I read in 'Aeroplane', about the RAF Apprentice School at Halton in the 1940s: - new entrants' first task was to make a 1" ball out of a 1" cube of mild steel, using a bastard file, within a time limit.
Similar tests were in use in the early 80's when I did my engineering training: several small pieces of 1" steel, hacksaw, files, chalk, and a piece if 1" plate - make a cube that fitted all ways round with no gaps into a square hole you made in the plate, then repeat making a 1" ball in the same hole - also did the square in a square hole later using machine tools as well
When I lived in Africa, if I was working under the Landy , I could say to my Rottweiler, pass me the 17mm spanner...and he would...the locals were amazed and called him The Mechanical Dog..
now that I like.........did you get beyond the 17mm ?
