westhinder
Anyone direct experience with an aftermarket Tides Marine sailtrack added to an existing mast? Pro’s -cons?
I fitted one to my Malo 36 with a Selden mast in 2012. Huge improvement on original plastic slides. Smooth hoist, and I can still let the main halyard go and the sail drops neatly into the stackpack. It was fitted in conjunction with a new mainsail and has worked perfectly ever since.Anyone direct experience with an aftermarket Tides Marine sailtrack added to an existing mast? Pro’s -cons?
Not really a concern in UK but over on Sailing Anarchy there is often chat of the track failing due to UV in warmer climates. Wouldn’t put me off fitting it but if OP’s is a Med boat might be worth investigating.
Fitted one 2 years ago. Does everything claimed. Easy to fit, although when you first unpack the track it looks like a bit of a monster. My mast is short around 10m and I was able to do it single handed but would imagine a taller mast might need a second person to control the tail as you push it up the slot. Not sure that UV is a problem now. The reports on this are about tracks 15-20 years old, but I understand from the guys at Tides (their European office is local to me) the material used now is different and more UV stable.Anyone direct experience with an aftermarket Tides Marine sailtrack added to an existing mast? Pro’s -cons?
