lustyd
You might need to explain with the aid of props and puppets, but I'm still not sure it'll workSigh
There's a trial going on somewhere in Scandiwegia that uses sand as a storage medium. Use solar/wind to heat sand "to too hot to touch but not hot enough to become glass" (400-600 C, I think), and it will stay hot for a significant enough time to make it meaningful as a storage medium. Run a heat exchanger around it, and you get a viable district heating system, and can convert the steam back to electrickery.Agreed. A major, as yet unsolved problem, is storage of energy.
mate of mines wife found out a out that when she stood on a patch of sand that had had a disposable bbq on it,serious burnsThere's a trial going on somewhere in Scandiwegia that uses sand as a storage medium. Use solar/wind to heat sand "to too hot to touch but not hot enough to become glass" (400-600 C, I think), and it will stay hot for a significant enough time to make it meaningful as a storage medium. Run a heat exchanger around it, and you get a viable district heating system, and can convert the steam back to electrickery.
I suspect, however, that its maritime efficacy may be limited.
Sigh!The problem is Frankie that some key board warriors see things in black and white. I introduced a simple question, what did the power in the wind do downstream of it before we extracted terrawatts. Nothing judgemental, just a simple question. Nothing about climate change!
Surely a simple question for a scientist such as yourself to answer? You are a scientist arent you?
There was a similar trial some years ago in N Africa, Morocco, perhaps. I have lost sight of that but this, Finnish "sand battery" offers solution for renewable energy storage is a similar version. Of course pump storage has been around for nearly 100 years.There's a trial going on somewhere in Scandiwegia that uses sand as a storage medium. Use solar/wind to heat sand "to too hot to touch but not hot enough to become glass" (400-600 C, I think), and it will stay hot for a significant enough time to make it meaningful as a storage medium. Run a heat exchanger around it, and you get a viable district heating system, and can convert the steam back to electrickery.
An H-bomb is a relatively small item contains a vast amount of energy. Once exploded, there is no way that energy could be put back in another container. A moderate size thunderstorm is similar to an H-bomb.Why would I need to? I also don't have a plan on how to travel at light speed, but I've not ruled that out because I have an open mind and believe most things are achievable in the long term.
With or without due respect, I don't think that answers the question. Clearly, wind energy is dissipated by friction and ultimately by heat, but I am wondering what local effects might result from converting most of the North Sea into wind farms. Scandinavia and Holland/Germany might find themselves with lower average wind speeds over a large area. I don't imagine for a minute that this has any connection to climate generally, but the local effects might be measurable (or not).Sigh!
As ever, “simple” questions about weather can rarely be answered simplistically. A simple answer needs some explanation. I will do my best but realise that my answer will be twisted and distorted by some in this thread.
The sun heats the earth and the earth radiates that heat back out to space but, in doing so, the atmosphere is heated and cooled due to absorption by GHGs. Due to variations in the earth’s surface and cloud cover the heating/cooling varies on all time and space scales. This creates pressure differences so creating wind systems of sizes varying from small scale turbulence up to the major lows, highs, Trade winds etc.
There is an old saying that -
Big whorls have little whorls feeding on their vorticity.
Little whorls have smaller whorls and so on to viscosity.
All that is background that might help you to understand.
A simple answer to your question is that , energy is continually being taken out of the atmosphere. The energy not used to drive wind turbines will dissipate through friction and viscous effects.
It could just as easily result in very high wind speeds as the spinning planet and atmosphere hits a man made “wall” causing a vacuum behind the wind farm. The interesting question is where the air then comes from, north or south, to know whether they get hotter and drier or colder and wetter.With or without due respect, I don't think that answers the question. Clearly, wind energy is dissipated by friction and ultimately by heat, but I am wondering what local effects might result from converting most of the North Sea into wind farms. Scandinavia and Holland/Germany might find themselves with lower average wind speeds over a large area. I don't imagine for a minute that this has any connection to climate generally, but the local effects might be measurable (or not).
And yet we see nature doing exactly this all the time in stars and black holes, so we know for sure it’s not only possible but being done. The challenge is scaling it down and engineering it.An H-bomb is a relatively small item contains a vast amount of energy. Once exploded, there is no way that energy could be put back in another container. A moderate size thunderstorm is similar to an H-bomb.
Although I have motored through the odd wind farm I have only once been through when there was a sailing wind, of around 15 knots. This was a moderate-sized farm south of Falster and I remember losing the wind almost entirely on the way through, and as far as I recall it wasn't until 10-15 miles downwind of the farm that we got the full wind again. There may be a shadow upwind as well but this will only be a mile or so.It could just as easily result in very high wind speeds as the spinning planet and atmosphere hits a man made “wall” causing a vacuum behind the wind farm. The interesting question is where the air then comes from, north or south, to know whether they get hotter and drier or colder and wetter.
This is more like it, a reasoned take on what is going on, cause and effect, xactly what I had in mind when I first posed the questionsWind farms. I fly over wind farms a lot. On a windy day it is clear that there is turbulence on the water down wind and not up wind. That makes sense since the wind turbine takes more or less laminar 1D air flow, bounces (layman’s term given the complexity of aerodynamics) off the blades and given a 3 dimensional component. Some of that has downward vertical component which hits the water, hence the patterns I see on the surface. As wind passes through the field, electrical energy is taken out and air has been accelerated away from its 1D regime. The net result will be a decrease in the horizontal component of wind speed and thereby a change in pressure.
does that mean the winds are going to get less as we put more turbines up? I doubt it because I believe the world is a net windier place each time we pump more fossil fuels, co2 from working soils and drying wetlands etc. into the atmosphere. As someone has already said, more co2=warmer atmosphere =more wind. I suspect the world will become a windier place despite our best efforts to harness the energy. And yes downwind of a wind farm is going to be a bumpy place to be if you rely on the air for motion/support.
As for solar (pv or water or GSHP) those mechanism will in theory have a net cooling effect on the atmosphere since energy is removed/shielded from the soil, but I suspect that any such difference is more than offset by urbanisation, agricultural practices and changes of land use.
The question posed was ”what did the power in the wind do downstream before we extracted power?”This is more like it, a reasoned take on what is going on, cause and effect, xactly what I had in mind when I first posed the questions
You really are clutching at straws.And yet we see nature doing exactly this all the time in stars and black holes, so we know for sure it’s not only possible but being done. The challenge is scaling it down and engineering it.
That is what I would expect. Local effects, fairly limited in extent. I would expect flow to be more turbulent. However, do not forget just how variable the wind can be even over the sea well away from land. Have you never sailed into a hole?Although I have motored through the odd wind farm I have only once been through when there was a sailing wind, of around 15 knots. This was a moderate-sized farm south of Falster and I remember losing the wind almost entirely on the way through, and as far as I recall it wasn't until 10-15 miles downwind of the farm that we got the full wind again. There may be a shadow upwind as well but this will only be a mile or so.
Created waves. Still does.The question posed was ”what did the power in the wind do downstream before we extracted power?”
Every time I tried to race on the Blackwater, with the result that the rest of the fleet swanned past me. The most striking hole I encountered was when sailing past Mons Klint, a massive cliff in Denmark. There was a stiff 15-20 knot wind blowing ashore from the east and we were a good mile from the cliff, but drifted along for the whole length of the cliff before romping along again.That is what I would expect. Local effects, fairly limited in extent. I would expect flow to be more turbulent. However, do not forget just how variable the wind can be even over the sea well away from land. Have you never sailed into a hole?
