Bouba
I just hope this young guy knows what he is talking about...
That’s possible...but I looked through the thru hull fitting and the ball looked ok except for surface rust and I tapped it with a big screwdriver and it seemed solidI reckon the ball valve is some kind of stainless and less noble than the skin fitting so its turned to a ball of rust.
Only the fittings are - not the body of the valve. Common misunderstanding. The ball is usually nickel plated brass running in a teflon seat within the body so seawater does not touch the body. As i said the problem is the fittings either end which may be brass, DZR or bronze - difficult to tell visually but your skin fitting shows no external sign of dezincification, but difficult to tell with the hose tail without taking the hose off.This is an underwater fitting so it’s constantly exposed to seawater...I gave it quite a bit of wellie today trying to work the ball valve...so it feels strong..but if I can find the composite Trudesign parts tomorrow then I will install them
I’ve always wanted to replace the fittings with composite ones...and replace the zincs with aluminum...just another job on the never ending list...there are only three or four other seacocks...and they do workHave you got a replacement regime ? What are the other TTH fittings and valves like on your Beny ?
How often were they all excised when in use ?
I was thinking that today but I didn’t have one with meHave you checked any of this with a magnet?
I have also come to the conclusion that the valve is good...but the boat is out the water an if the parts are available I might as well do itOnly the fittings are - not the body of the valve. Common misunderstanding. The ball is usually nickel plated brass running in a teflon seat within the body so seawater does not touch the body. As i said the problem is the fittings either end which may be brass, DZR or bronze - difficult to tell visually but your skin fitting shows no external sign of dezincification, but difficult to tell with the hose tail without taking the hose off.
I bet you a virtual pint that if you do replace everything - skin fitting, lock nut, valve and hosetail - you will find the existing in near perfect condition.
There is a lot of hype and scaremongering about through hulls and valves that is not supported by evidence - yes they can dezincify, particularly the hose tail if brass but there are literally hundreds of thousands installed in boats and there is no sign of an epidemic of failures let alone sinkings.
The boat is going in the water on SaturdayThis has all the makings of another Bouba saga, like the Great Fuel Tank Leak of immortal memory.
I'll order in a sack of popcorn.
Fingers crossed bungs at handThe boat is going in the water on Saturday
Ye of little faithFingers crossed bungs at hand![]()
I expect a new thread on Saturday entitled:The boat is going in the water on Saturday
Or how to fix a rusty generator.I expect a new thread on Saturday entitled:
"Any ideas on how to raise a sunken motor boat without spending any money?"
By bunging up the hole and pumping out...I expect a new thread on Saturday entitled:
I’m hoping that it’s just a water elbowOr how to fix a rusty generator.
