Halo
Ideally I would like to replace my skin fittings and seacocks etc with Trudesign composite ones. The trouble is my seacocks are grouped together under a floor board at the bottom of the companionway steps. The arrangement from new is that a 90 degree M/F elbow is screwed directly onto the skin fitting and the seacock into that. So the seacock is horizontal.
The info from Trudesign and on the various youtube videos is to screw the Trudesign seacock directly onto the skin fitting and not via their 90 degree composite elbow. This makes it stick straight out away from the hull and needs a lot of room
The PBO video says if you cant fit the seacock onto the skin fitting then make a new skin fitting hole elsewhere - i e where you can accomodate the sticking out seacock etc. The trouble is that is simply not a sensible on my boat.
Has anyone else faced this problem and come up with a solution ?
If not I may be back to the original layout and DZR
