Through Hull Advice Needed
Frayed Knot
3 Nov 2011
Suffolk - Home and boat
Tranona's post is spot on, but in addition it is not possible to protect fittings on two sides of the hull with one anode. An anode needs to 'see' the object it is protecting and ideally be close to it. If it was necessary to protect skin fittings and valves with anodes they would need one per fitting. A good copper alloy, bronze or DZR, needs no protection whatsoever and even standard 60/40 brass fittings, with which most boats were fitted until quite recently, lasted for many years without significant corrosion.
Thanks for that. Yes, I have anodes on both sides of the hull as well as dedicated ones on the prop & bowthruster, all of which waste quite quickly & need replacing annually - hence my concerns. My boat is berthed at the harbour’s edge, next to a steel piled wall & since a large work barge has been placed nearby I’ve noticed an increase in in the wastage which adds to that concern.
VicS
13 Jul 2002
Thanks for that. I’ll phone around tomorrow and see if anyone can supply them as nobody I’ve found actually lists them. Lee San seem to have the largest range available so I’ll try there first.
Tek Tanks has in the past stocked tru design and still seems to.
https://www.tek-tanks.com/trudesign/
What you are looking for is on this page
https://tektanks.wpengine.com/wp-co.../90-Degree-Male-Female-Threaded-Connector.pdf
BUT only suitable for above waterline use. Below the waterline the valve should be directly fitted to the skin fitting.
VicS
13 Jul 2002
If you use shorepower be certain to have a galvanic isolator .
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
If that's the case I'd glass over them and either move above the waterline or just not have deck drains. Decks are self draining as a general rule, cockpits only need drains because they are enclosed. Had I kept my old boat I was going to glass in some pipe to remove all the failure points, that's also an option.
My boat has deck drains because there is a raised toerail all around the deck. Water lies naturally in the midships area and drains through the scuppers. They exit below the water line to avoid unsightly streaks on the topsides. They have been there for many years now, nearly 40, and never given any trouble.
One of them doubles as the exit port for the above-deck bilge pump.
john_morris_uk
3 Jul 2002
At sea somewhere.
Sounds perfectly ok and very neat.
I’ve noticed that some people seem to have extreme paranoia about skin fittings. One hears stories of people removing them and glassing over the hole. Not sure what they do with grey and black water or where they get seawater from to flush the heads etc.
Tranona
10 Nov 2007
The whole point of having them drain below the waterline is to avoid water running down the topsides. Such systems are popular with high class boats as it avoids having slots in the toe rails/bulwarks and the streaks you often see on topsides. Decks are designed so the drains are at the lowest point and the outlets (in this case 45mm) large enough to cope with the volume of water.
Tranona
10 Nov 2007
All good advice, thanks. And yes, I will ignore it! I agree totally re the double clipping but as you say: the surveyor said it, so if anything went seriously wrong I would be in breach of my insurance terms for the sake of about two quid…
Just a thought; if I were to simply replace the gate valve with a DZR ball valve & if you are correct that the elbow is bronze (I think you probably are) would that constitute dissimilar metals in contact?
The bronze and DZR are fine together as they are virtually the same potential and as they are not immersed in seawater together it does not matter anyway. The only part of a through hull that is immersed in seawater is the bronze flange. I expect that gate valve has a bronze body and no signs of corrosion. The weak points on that type of valve are the spindle and the tendency for the plunger to get stuck to the body with deposits. Given that they are open all the time to let the water drain from the deck when you do try to close them the plunger is seized and the spindle can sheer.
On the subject of anodes, what you currently have is normal - those are two of the common situations where they are necessary.
ean_p
28 Dec 2001
Humber
Is this restriction, do we know, because the fitting is 'plastic' or is the restriction that the first thing on the skin fitting shall be a valve regardless of the material of construction?
Either way I think that I'd be inclined to ignore it as long as the fitting ( the bend in this case) was of quality construction.
ean_p
28 Dec 2001
Humber
My only ad vice regarding through hull fittings would be don’t use plastic seacocks or through hull fittings.
My use of the word 'plastic' in the above post is in specific reference to the TruDesign item under discussion which is in reality a glass-reinforced nylon composite material. Hence why the word plastic was placed in inverted comma's. I believe they ( the TruDesign items ) carry all the required certifications and acceptances of the major approval bodies.
Have you a reason as to why you would advise against them?
Tranona
10 Nov 2007
Forespar Marelon from ASAP Supplies offer composite sea cocks with a 90o outlet. They do not list one with a 32mm / 1 1/4" outlet but I suspect it is part number 3-80124
Forespar | ASAP Supplies
If you look at the OPs installation, none of those would fit. Why make things so complicated when the only problem he has is the gate valve is seized (and is not ideal anyway) but the rest of the bronze fittings seem to be in perfect condition after 40 years. Replacement with a DZR ball valve is almost half the cost of a Forespar, and even a bronze one is 20% cheaper and a direct replacement for the current valve.
