You get nowhere on yt without a bit of sensational rubbish. But broadly he’s right. The biggest obstacle really is that so far, there isn’t the ability to stabilise the output voltage. I’m sure an input/output controller could be built that would make it put out 12.5V from full to empty, but until then, they won’t work well on a boat. Then doubtless there’s a lot of other improvements that will make early versions obsolete.This has got to be the most biased negative video I have even seen. If you are bored count his negative comment's and negative words and you will have a job to keep up with him. I hunger for scientific facts and results not this prats inflated biased ego.
This has got to be the most biased negative video I have even seen. If you are bored count his negative comment's and negative words and you will have a job to keep up with him. I hunger for scientific facts and results not this school boy prats inflated
Trying being a little more scientific and fact based.
How much more scientific do you want. Do you not understand?Trying being a little more scientific and fact based.
There are dozens of sodium batteries on sale now. I understand the science is in its infancy but do you think all these companies and investors have thrown their money away. The commentator on your video is an annoying smug prat and that's how he gets all his "clicks" As I said he is an amusing smug prat at times but hardly scientific.How much more scientific do you want. Do you not understand?
I’ve been looking at them. So far, they are not more energy dense, nor are they lighter, per Kwh. They don’t do as many cycles as a good Li battery yet either. Charging rates are important for cars, but utterly irrelevant for boats, or home solar installations. 3/10, must improve.There are dozens of sodium batteries on sale now. I understand the science is in its infancy but do you think all these companies and investors have thrown their money away. The commentator on your video is an annoying smug prat and that's how he gets all his "clicks" As I said he is an amusing smug prat at times but hardly scientific.
Clearly not. His biggest issue will be that Sodium doesn't compare well with LFP, he has a Bee in his bonnet about LFP, which he also doesn't understand.How much more scientific do you want. Do you not understand?
He knows more about battery tech than you will ever knowThere are dozens of sodium batteries on sale now. I understand the science is in its infancy but do you think all these companies and investors have thrown their money away. The commentator on your video is an annoying smug prat and that's how he gets all his "clicks" As I said he is an amusing smug prat at times but hardly scientific.
One of the big issues that Will demonstrated was how low the voltage goes. Getting much below 12v isn't any use as a battery in a 12v system. Having so much of its capacity below 12v renders a chunk of sodium battery capacity unavailable to us. This derates the battery so you need more of them to give you the stored capacity of lithium.I’ve been looking at them. So far, they are not more energy dense, nor are they lighter, per Kwh. They don’t do as many cycles as a good Li battery yet either. Charging rates are important for cars, but utterly irrelevant for boats, or home solar installations. 3/10, must improve.
Simplistically, determine how many cells would be needed so that the battery never went below 13V, then add a DC-DC charger to give a constant, stable 12V. This could be built into the BMS. Doesn't overcome the other current drawbacks, such as charge acceptance, which is of particular importance to boat use and solar charging.One of the big issues that Will demonstrated was how low the voltage goes. Getting much below 12v isn't any use as a battery in a 12v system. Having so much of its capacity below 12v renders a chunk of sodium battery capacity unavailable to us. This derates the battery so you need more of them to give you the stored capacity of lithium.
That also states, amongst others:I was looking at the spec sheet for one of these:
https://cdn.shopify.com/s/files/1/0...ange_-_Instruction_Booklet_1.pdf?v=1748611953
They require a charging voltage of 15.5v, quite high. And at 20% state of charge the voltage is moving below 11v. Kind of on the low side.
Price wise they aren't cheaper.
Other than cold changing (which could be significant to some), I'm not really seeing many advantages here.
The biggest producer of lithium is Australia- I don't think they have kids mining it there.Sodium will be the next big thing because it doesn't involve kids mining lithium
To ensure the life cycle of the battery and for safe use the following must be adhered to:
● The battery must not be stored in high temperature locations, in direct sunlight or left inside a vehicle in hot weather.
● The battery must only be charged using a Sodium-Ion charger.
● When charging, the battery must not be left unattended or when charging for long periods.
● When fully charged the battery charger must be disconnected from the terminals and the mains power supply.
● The charging premises must have an appriopiate fire detection and alarm system and appropriate fire prevention
equipment.
● The battery charge state should be checked regularly and must be recharged to 80% at least every three months when
in storage.
● The battery is not able to be transported on passenger flights.
Just to be a bit of a "Devils Advocate" I would think that most if not all of theses conditions would be applied to any battery or charging facility.That also states, amongst others:
equipment.
in storage.
