Piers
This is all so helpful. I've now so much to read and learn.
How about a whiteshark.
Seem to hold their money well.
Larger ones even have a loo!
Have a look at the cobra range of RIBs https://www.cobraribs.co.uk/cobra-nautique-outboard/#nautique-7-7, Ribcraft leisure range http://www.ribcraft.co.uk/ribcraft-810s-leisure/ and Redbay http://www.redbayboats.com/leisure-landing-page-2/ These are all plush leisure ribs built on serious commercial hulls which will look after you.
Although if I was in your shoes I would be looking at hard boats also, like an Axopar 24 http://www.axopar.fi/range/axopar-24-open/
Lots of good reading here, but as far as an Axopar is concerned, it just doesn't 'look right' in my book. That's the more sensitive language for 'ugly'!
Any Ribcraft over 7.5m and 200hp would be a good choice.
I wouldn't bother with twins - PITA and you need separate fuel systems to make them worthwhile.
PITA? That is unless your manoeuvring and twins are far superior to a single, not forgetting the redundancy of a second engine. Worthwhile...............definitely, if you ever own a twin engined boat, it’s VERY hard to go back to a single.
Watched thread with interest
In No particular order, my thoughts
We have a Humber 6.5 in the 'Fleet'plus a Ribeye 7.85 a Redbay 8.4 and a Ribcraft 9
If I was to choose one of them for my own use it would be the Redbay
The Humber is a brill training boat
The Ribcraft by the way of its seating a great Trip boat
Nicely put.
The Ribeye is a jack of all trades but suffers so
The Redbay is on a Par if not better in some areas than the Ribcraft as for build quality
IMHO the Ribeye is not as good as all tothers, neither is its seakeeping
Nowt wrong with it , it's just as good as tothers, hull shape tube configuration etc
Where you are is similar to Me in that you have loads of current which when its 'wind against' you have to on your mettle and need a boat/rib that can handle the short choppy seas You will encounter on occasions no doubt
All the above 'Makes' I have indicated do not make a bad or poor boat
If I was going to choose the engine
We have Yamaha, Evinrude and Suzuki at the moment
Honda prior on the Largest, the Ribcraft, which we changed to Evinrude e tec (twin)
E TEC on the Ribeye and Suzuki on the Redbay
Oh on another rib we have a Suzuki too!
Forgot about that one but it is an old hull and the makers are no more
I would be hard pushed to 'find' a favourite engine
Lean towards the new Suzuki 'lean burn' I think for leisure use
Easy to service is one advantage
Although Honda were the first to market large outboards, in my experience the power to weight ratio has been surpassed by the other makes mentioned
Just my thoughts and experience over the last few years operating RIBS commercially and for leisure.
Not in my experience. I've had twin outboards (2 x Yamaha F200) and happily went back to a single (Suzuki DF300). Half the servicing cost and 2/3 the weight on the back.
