Hurricane
Hang on though - if your boat can't be safely handled at less than 5 knots then either the boat is really badly designed or you need to take some tuition. The thought of someone having to weave around the fairway in a marina at 5 knots in order to be able to steer is frightening.
Yes, I do appreciate your point BUT.....
Have you ever driven a big mobo?
We don't have the same control that yachties have.
We are not blessed with a big keel underneath to stop any drift.
Essentially, our mobos have flat bottoms so slip very easily sideways.
At low speeds we even used this in a controlled way to manoeuvre the boat.
Speed helps - the rudders can then be used but speed causes danger so we resort to slipping sideways through the water.
Handling a yacht with a keel is completely different - much more intuitive - far less side slipping (in most cases none) so you end up driving into and out of a berth
I don't know if I'm speaking for others but thats the way I see it.
Believe me, I come from the sailing world - you need to try and steer a mobo before making statements like that.
Sorry, I'm not picking on you.
But, if you get the chance, you should have a go and you will then have a completely different respect for mobos - IMO
