nashynetfit
Dear forum
Last weekend I took my boat out for a test run on the gearbox, as have recently had to do some major work on this, but after just 2 minutes running I could see some smoke coming from the rocker cover, and also from the dip stick area, so headed back home.
Just prior to stopping I had to put the boat in reverse at high revs, which she did then cut out.
Since then she has struggled to turn over correctly, at first the starter seemed to turn, but it sounded like the batteries were flat, so batteries charged and even new ones added just result in a heavy clunk from the starter.
Both the fly wheel and alternator belt move a few mm but I can't turn the engine over by hand using the larger pulley, tried connecting a spanner to it, but there is no bolt end etc. mole grips would simply turn around the bar.
I had checked the engine oil about a month ago and all was fine, but now the engine oil was very low, so have filled to correct level, but my concern now is that maybe I may have seized the engine.
I would be grateful for any tips if possible on what to do, was advised it may be a starter motor jamming, but have given it a light tap with a hammer but no different, but feel it strange that last weekend it was trying to turn over, but now it's simply just clunking heavy.
Engine is a 2.2 diesel bmc
