Thick Question - Shore Power Cables
Slipperman
30 Sep 2009
Hampshire
My shore power cable, which came with the boat, has a very stiff plastic outer covering which means it kinks like crazy and is a bit of a pain in the neck. I have noticed that some boat owners have much more user friendly, flexible power cables, but the chandleries only seem to sell the sort I have. Is there a reason for this i.e. is there some EU reg which requires a certain specification? If not, can someone advise me where I can get nice flexible cable which will also be safe to use? (The end fitting are make 16 amp, 230 volts - so presumably 13 amp cable would not be up to the job?).
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
I wonder if it is very old and UV damaged. I have never seen a cable that kinks in a chandler, if they did they would never sell any. Have a look again, they are generally sold coiled up.
sarabande
6 May 2005
most caravan and marina cable is 16 amp, and would indeed have to be 2.5mmsq to meet that spec.
Have you tried twisting the cable as you coil it ? If the internal strands are twisted (very likely) that is the only real way to achieve a neat coil, unless you use a frenchman.
laika
6 Apr 2011
London / Gosport
Google for arctic cable - it's more flexible.
+1. 3 core blue arctic. I bought mine from an electrical supplies place but it's probably cheaper online. I seem to remember calculating that 1.5mm would be sufficient for my needs but as I was buying quite a long lead I went for 2.5mm to be on the safe side
reeac
6 Jun 2003
Orford, Suffolk, UK
I think that this is an application where you need the mechanical sturdiness of the heavier cable as much as its current carrying capacity.
NickTrevethan
3 Dec 2011
London
I mDe up one with orange aRctic cable. Got mine at b and q. Connectors from a chandlery. Just be careful to wire it right. I double checked mine with continuity tester.
VicS
13 Jul 2002
I dont think the orange cable is arctic grade. B&Q do however sell arctic cable but ITYWF its rather more expensive than other sources suggested
NickTrevethan
3 Dec 2011
London
Vic, this was 10 years back. Definitely arctic. And 12 metres was 30 to 40 pounds. The did a great line in armoured too, which used for the new ring main I installed.
David2452
6 Jun 2001
London & Fambridge
The power cable with my boat is marvellously soft and kink free. Turns out the insulation is polyurethane (PUR) instead of PVC. I don't know if that's what artic/arctic (which is right?) cable is.
Mine is this http://www.es-store.co.uk/extension-cables-and-accessories/SHORECORD-EXTENS-10A-25M.html
Probably HO7 cable, far more suited to long cables, also more abrasion resistant than arctic and really the first choice for things like shore leads, though arctic seems to have be come the convention.
Plevier
22 Aug 2008
Brighton
Mine is definitely PUR not HO7 and it is excellent, a delight to handle compared with PVC.
Artic/arctic is just a more flexible PVC isn't it? Lots of plasticiser?
VicS
13 Jul 2002
HO7 is, IIRC, more abrasion resistant and is, or should be the choice where cables will be on the ground and walked over by many pairs of feet. At outdoor events for example.
