There's damp in that thar deck
Greenheart
29 Dec 2010
Ah, how proud I was of my shiny chrome rowlock-sockets last year. And in fact the chrome is still pretty good...but the machine-screws have rusted horribly...
...I begin to get the feeling there's moisture in the wooden core under the GRP! Is my best bet to use bronze screws, or monel, or something else?
Greenheart
29 Dec 2010
Ah. Thanks Mr Morris. That had occurred to me, but I reckoned I was thinking too hard.
I bought Duralac bedding compound a month ago to seal the new rivets in my spreaders. I'd been thinking there was enough in the tube to last me several lifetimes.
Maybe I'll have a Duralac weekend, going round the boat gradually insulating all differing metals from each other. :rolleyes:
Kelpie
15 May 2005
Afloat
Are the machine screws 316 or A4 stainless? You can get small quantities on a Ebay if you don't have somewhere locally.
On sealing, Duralac us what you need for dissimilar metals, but you should also put something on the screw where it goes into the wood. Un thickened epoxy would be good but varnish is much easier.
prv
29 Nov 2009
Southampton
Mild steel, I reckon, possibly zinc-plated if you're lucky.
You want stainless, Dan!
And some sikaflex (or alternative goop, but not Duralac for goodness sake!) under the plate so that you're not introducing more water into that core.
onesea
28 Oct 2011
Solent based..
Dan I know your on a budget but S/S is the way to go. If you find the right Chandler you can buy them individually at the right size for the job. I always buy 2 extra for the bilges and have a tool box with a few spares in that have built enough I often do not need to go to the Chandler.
Seajet
23 Sep 2010
West Sussex / Hants
First, as mentioned check the screws are stainless. Simple silicone sealant from a DIY bodgers merchant like B&Q etc would be fine.
The really infuriating thing about Sikaflex ( A Rolls Royce solution for a BL Marina problem ) is, if one has half Aberdonian ancestry like me, it's truly painful to only use a smidgin of the very expensive stuff then the rest in the tube sets as solid as Stonehenge, unuseable...:rolleyes:
Greenheart
29 Dec 2010
Thanks for all the replies, gents. The rusted machine-screws were indeed B&Q cheapies, I don't know why I'd thought they'd be sufficient.
I'll certainly replace them with stainless, and I'll fill the hole around each bolt with the mastic I bought to gum-up my leaking self-bailers. If that'll do it...it'd certainly keep them dry.
Pete, I only mentioned Duralac because I had supposed that the bolts' deterioration might have resulted from their damp contact with the nobler metal of the rowlock-sockets...
...but the fact that the starboard bolts are in worse condition than those on the port deck, suggests that more probably it's just the localised damp in the wood core on that side.
I've more or less given up worrying about that moisture imprisoned under the glassfibre. I expect it could be removed, but only by time-consuming work which is hardly vital.
john_morris_uk
3 Jul 2002
At sea somewhere.
A fastenings shop (a proper one!) will almost certainly be a lot cheaper than a chandlers. Or order on line from a choice of several suppliers.
If the deck is a cored deck, it would help a LOT to use a bent nail or similar and get the core (balsa?) out from round each hole and then fill with thickened epoxy and re-drill.
richardh10
7 Jul 2007
on the move
Falcon Workshop Supplies do a lot of marine stainless fittings. They have an ebay shop, or you can ring them and place an order. They do small quantities, and when you see their prices you'll never buy from a chandlers again. Free next day delivery on most things
