The Real Flipper
Eventually I will learn to simply not look anywhere I have not carefully looked before, because every time I do- issues!
LOL.
So this time it's through hulls. Now I was told by vendor and surveyor that the through hulls were done in 2019, new ones fitted.
Now I look closer and they actually don't look so swell.
The first one is in the engine compartment and seems to have rust.
The second two are accessed through a little 4 inch by 6 inch cut away under the heads, and they don't look so swell either.
By the way the heads stinks and I keep the door closed because it's surprisingly strong. The boat has no holding tank, as you can see, from the heads out.
The second two look like a nightmare to replace as its only possible to get one hand in there at a time and there is no access from any other direction that I can see without of course removing the engine.
Not to get ahead of myself, what do you guys think?
Once again, any suggestions much appreciated
LOL.
