Sixpence
Thanks everyone, I think
Thanks everyone, I think![]()
Is that it?
IS THAT IT!!!!!!!!
You come in here, causing a massive punch up, destroying the calm with your contentious post, and then just come back in at the end with a one liner!!?
I shall have to refer this to the Ethics and Standards Committee.
"Buck-Up" Dave
Fred Drift - Tide Drift its all the same![]()
I do apologise, I hab a code add find de Seff coast stuff confussing
Think I understand the basic up and down stuff now though, thanks. So if I cast off at high tide and use the tide flow to help push me clear, and the passage time from mooring to open water takes three hours, this would explain the cork from bottle effect on reaching Boston Broad (I think) buoy, which marks the entrance to the approach to my mooring.
If I understand this sort of properly, if I'm on open water at high tide, with an intended passage plan taking me in a straight line from point 'A' to point 'B' and estimated at twelve hours crossing time, then ignoring any other factor, if I maintain course for the duration of the crossing, then any tidal flow affect will be cancelled out ?
Then if my passage plan is similar but only a six hour duration, then I need to adjust course to take into account the drift, which will be most at around three hours after high tide ?
Sorry if it sounds a bit thick to some![]()
I see the time warp is still playing up too![]()
Dave this just proves you're winding us all up. I refuse to take the bait this time!![]()
It will all come out in the Wash Dave. nite nite
If it hasn't been mentioned instead of twelths I have used %s as follows.
1st hour 10% of range
2nd hour 15% of range
3rd hour 25% of range
4th hour 25% of range
5th hour 15% of range
6th hour 10% of range
This is much easier to work out than twelths and as an an approximation does the job.
