jimi
Some of you do like to complicate things by looking at the detail.
Put any shape into an airflow, and it will change the momentum of the airflow; so a force will be created.
If it's a cylinder, it'll slow the airflow down (drag); the pressure at the front of the cylinder will be greater than that at the back (bless Bernoulli if you wish; whether it's turbulent or laminar, friction slows the air down . . .)
If it's longer than it is wide, it may be a plank, a symmmetrical aerofoil, an asymmetrical airofoil, a thin curved sheet, a sail, I don't care. But any of these shapes could be rotated relative to the airflow, and (unlike the cylinder) this will create changes of direction of the arflow as well speed.
Sure, with a bit of twizzling, you can find an angle at which they're just a bit of a drag.
But, at any other angle, they will not only slow things down a bit, they'll also change airflow direction. That's a change in momentum - which will be matched by a force. Change in momentum=force.
Do vectors to find how much and in exactly what direction the resultant force acts. But crudely, it's at right angles to the mean flow - half way between input and output (ignoring the additional element of drag). The force manifests itself as a difference in pressure each side of the aerofoil, explained by Bernoulli, flow being faster on the "outside" than on the "inside"
You don't have to have think "inside" vs "outside" either. Water and spoons have been mentioned. Flow direction will change whether the flow is just around the convex, or just inside the concave, and the force developed will be the same if the change in flow angle is the same. Take a pause and consider how many water sprinklers work - changing water direction through a right angle.
That's how any shape creates forces in an airflow. Changing momentum of the airflow. Over simplifying, direction change=lift, speed change=drag (or thrust if it's had energy added by going thru a device!)
For doubters, aircraft with asymmetric aerofoils can still be made to fly level upside down - if they're strong enough and the engine doesn't stop.
So all arguments about "what shape" are not very relevant. These shapes are just variations of machines which change air momentum. Parachutes are great at drag, but poor at lift. Gliders are brilliant at lift, and create very little drag indeed. Sailboats have two airfoils pushing against each other, one under water, and one above which flips to match the airflow direction. This incidentally creates a heel angle, but the net result is a bit like sqeezing a damp lemon pip - there's only one way left to go.
Not exactly the rocket out of the back; more like the only remaining option!
as ever from JimB, well expressed sense.
