The panel's thoughts
The panel\'s thoughts
I'm looking at the brokerages in Spain for a boat to use as a school boat based in Costa Del Sol.
Ideal would to be flybridge 36 to 40 ft, cruise 18-20 max 25 plenty. Been looking at a Fairline 36
sedan and a Fairline 40 about 87 to 88. Whats the thoughts on the sedan is the hull anywhere near
as good as the P35 ?
"The Med has got me" (no not the Medway the other Med)
hlb
RIP
Any Pub Lancashire or Wales
Re: The panel\'s thoughts
Hmm. Thats a novel approch. "School boat" Is this for use as a school bus or as a class room?? I can send Tutts along to do the teaching, as long as the puples are very short. But after 20 years she still knows very little about boats except lassooing cleats and droping anchors. Will this get her in??
Got a 3mm drill stuck in the hull last week. No amount of mole grips or nufink would get it out. Hope this helps!!
<font color=red>The X Invisible White Man/forums/images/icons/laugh.gif<font color=blue>Haydn
lanason
23 Jul 2001
Malvern, Worcs
3mm drill !!!!!
What were you drilling into ????????????? Super Glue ???
What silly billy forgot to either do the chuck up or sharpen the drill !!!! /forums/images/icons/shocked.gif
Adrian
<A target="_blank" HREF=http://www.arweb.co.uk/argallery/kelisha>More Pics of Kelisha</A> /forums/images/icons/smile.gif
ccscott49
7 Sep 2001
If it's to be based on the costa del sol, what difference does the hull strength make? I sure they will both be up to the job!
hlb
RIP
Oh no. Brand new drill into engine bearers. And with the cordless drill. (Hand Drill). Only went in about an inch. Then stuck, solid, would not move.
Not hull strength hull sea keeping
lanason
23 Jul 2001
Malvern, Worcs
now the real bu**er is when you snap off a 3 mm drill real close to the surface - especailly when you cannot put the hole anywhere else !!! Did that the other day on Kelisha - had to get on the other side of the bulkhead and hit it back out with the side of a hammer (awkward and no room)..... took about 30 mins to push it back..../forums/images/icons/blush.gif and I did an Engineering Apprentiseship - double /forums/images/icons/blush.gif/forums/images/icons/blush.gif
Adrian
hlb do I have to explain further or is this just a wind up. Sea School stupid Just answer the
question bout sedan V P35 hull thought you'd enjoy answering that what with you
having Mucky Farter an all
hlb
RIP
Nop. The bugger was it snapped above the surface, so had to bash the top off. Is this leading some where??/forums/images/icons/laugh.gif
lanason
23 Jul 2001
Malvern, Worcs
Nop - not leading anywhere, just a little ditty. /forums/images/icons/cool.gif
You have been on here too long /forums/images/icons/wink.gif - looking for the hidden meanings to the messages or is that just your style ??? /forums/images/icons/crazy.gif
Adrian
hlb
RIP
Oh. I see. Did not know you were an expert sea teacher. Can I swap a bottle of soltron for one of those ICC thingies, or what ever there called??
Dont know nufink about tothers, just know how hard it is to sink a P35 I've been trying for years. And it's reputation of course.
From that I deduce you mean the F'lines hull will be equal to the P35 ok thanks cc
Oh I see the confusion its re my qualifications of which you know not, or do you have some
means of obtaining this knowledge to which lesser mortals are not privvy.
david_steward
Chatham, Kent
Re: No Brainer...
The Fairline 36 Sedan has the same hull as the Turbo 36.
Thats all you really need to know, coz the Turbo 36 has one the best hulls ever produced at around this size.
I can also speak from practical experience, rather too much on some occasions !!!
Please insert your smart ass pretentious tag line here...
Dave S
Re: No Brainer...
Thanks Dave a sensible answer at last
david_steward
Chatham, Kent
Re: If only...
I had a sensible shirt to go with that sensible answer.
Just thought I would get that in before Byron.
Dave S
Re: If only...
Dave I've also seem an 88 Failine 40 which looks the part wadda yer think
hlb
RIP
Re: No Brainer...
Oi. Thars nowt more sencible about him having a T36 to rant about. Than my P35. You still dont know if its better or worse.
Anyway if it's a teaching boat you want sumate with shafts, which is better to drive and anyway they will knacker the outdrives up in no time, shunting about back and forwards.
Re: No Brainer...
Shafts without a doubt, is the sedan 36 not shaft hlb ? If I was looking for a comparible
Princess about 1988 to 89 what do you reckon. The sedan & 40 were priced around 80 to 95k
