The Nautical Mile
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Is there a practical use for this discussion ? or is it just a theoretical one ? just curious.
Brian
Well there seem to be two opposing views. It would be nice to know which one is right.
What's the confusion? As you say the earth is not a perfect sphere, so the nautical mile varies slightly in length from 6046ft at the equator to 6108ft at the poles.This is not a problem because a Mercator chart has a built in scale of distances relating to that latitude.Instruments such as logs and radar are calibrated on a mean figue of 6076ft, now universally adopted as the International Nautical Mile
If you read \"Leckys\" and..
many other books you will fin that yes the NM does vary in length from the equator to the pole.
The mean length is about 6,076.8 feet (plus a few decimals), often taken to be 6,080 feet (accurate onlt at 48 degrees N/S). At the poles one NM is about 6,109 feet and at the equator about 6046 feet.
For those interested in more I reccommend Captain Lecky's "rinkles in Practical Navigation", written in 1851 and still useful (but forget right ascension).
I have just been refreshing my memory ref the actual distances of a nautical mile at the Equator and the Poles. I am aware of the internationally recognised figure 1852m. The Earth is an oblate spheroid (flattened at the poles), therefore the distance from the centre of the Earth to the poles will be less than centre of the Earth to the Equator. Therefore the 1 minute of latitude subtended at the Equator will yield a greater figure for a nautical mile than the 1 minute subtended at the poles. Various sources including this post and Wikipedia seem to have this muddled up, or is it me?
Look forward to replies
Minesapint
Since posting a couple of days ago (post no 19) I feel the point I was trying to make has not been understood.
A nautical mile was, is and always will be 1 minute of arc anywhere on the Earths surface as used today in sight reduction. There are an infinite number of nautical miles each measuring slightly more or less within a few metres. Due to the Earth being fatter round the Equator nautical miles measure more around the Equator and less at the poles. The slight differences in measurements may not be important but this is no reason for not wanting to have an understanding of the facts.
When I looked on Wikipedia I noticed the actual distances for a nautical mile were quoted incorrectly giving a shorter distance for a nautical mile at the Equator and longer at the poles. I then also noticed the same figures incorrectly quoted in 2 posts in this thread and elsewhere on the internet. If people are putting information on the internet it would be helpful to all of us if they ensured its accuracy. Of course it is possible and I have not checked that Wikipedia has been corrected and the incorrect posts above have been edited.
As indicated in my post no 19 I am aware of the Internationally recognised figure of 1852m but this is a different issue.
Mike
Daedelus
11 Jun 2006
Hants
What no-one appears to have taken account of is that measuring the distance will inevitably be distorted by the size of the waves on the sea.
Bodach na mara
21 Aug 2002
Western Scotland
The comment about a plane at an altitude of 30 000 ft reminds me of a question set by a maths teacher. An engineer runs a cable right round the earth at the equator. Just before he cut the cable, his boss said that it should have been on pylons 10 metres above the surface. How much extra cable is needed?
I should warn you that there is a bit of a trick in getting the answer.
newtothis
28 May 2012
Okay clever clogs, for those of us who can barely count on our fingers, how much? Please show your workings.
penberth3
9 Jun 2017
You need to give a circumference at the Equator?
Ah, mjcoon says you don't!
anoccasionalyachtsman
15 Jun 2015
We all know that the outside wheels of a car have to turn faster than the inside ones in a turn (otherwise there would be no need for a differential in the axles). But how many more turns would your left hand wheels do if your drove clockwise around the coast of Britain?
penberth3
9 Jun 2017
Same calculation with wheel track (say 2 metres) as the difference? Then divide by the wheel circumference for number of turns.
johnalison
14 Feb 2007
Essex
That wooshing noise is the sound of your answer going over my head.
He's saying that the answer is the same for all sizes of the Earth's circumference, even zero, when the circumference of this circle of radius 10 miles is given by his formula, or 2piR as it was in old money.
Bodach na mara
21 Aug 2002
Western Scotland
The following week the answer was given. The teacher reminded us of the question and asked where it was stated that the planet was Earth. Without going through the formula approach, he postulated that the planet radius was zero and thus the extra length was the circumference of a circle of radius 10metres :- 62 . 8metres
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
I think you need a powerful intuition to deduce that a bigger planet doesn't need extra girth...
