Sybarite
Cleverly disingenuous again
What they said was that Shannon had been, at that stage, test launched into 2m waves
They did not say that 2m waves were an operational limit nor even that Shannon can only be launched in waves less than 2m
Who is being disingenuous?
I asked the question; that was their response. They did not say "so far" nor did they speak of operational limits although that was what I was trying to get at. My point was that when the weather is at its worst it's highly likely that no lifeboat of any sort can be launched from a beach.
This was pointed out the last time you tried to imply that Shannon is a less capable lifeboat than the cheaper French boats
I never implied that the Shannon is less capable. I said that the French boats performed their function satisfactorily at a fraction of the price of a Shannon.
You had some good and valid points way back in the early days of these repetitive discussions with regard to the sometimes profligate spending on non-core activities (although, as has also been pointed out, the current management and trustees have taken significant steps in that area) but you lose the plot, and any likely support from all but a handful of people, when you repeatedly decry the provision of the best possible kit at the sharp end regardlessv of expense
Is the equipment more expensive because it is better or is it more expensive because they simply allowed the costs to run away through bad project management?
Most RNLI supporters, myself included, are perfectly happy. I don't care if Shannon cost double what it did if the RNLI can afford it. And they can so they should.
And I note you've yet to produce evidence of a cheaper alternative than can do what Shannon does. (You can't, of course, because the beast doesn't exist. That's why the RNLI had to develop Shannon from scratch and that was always going to be an expensive approach.)
The SNSM has jet propelled boats and so have shallow water manouverabilty and they do not need boats launched from beaches. So the Shannon requires a £1.5m trailor (2011 : £850k...) to get launched, and they have tested launches in waves up to 2m.
