roly_voya
There have been a nuber of pretty active threads since YM published the article on anchor is the december edition but I wanted to start a debate here because the way livaboard/long distance cruising boats use anchors is different. For one thing who else is going to anchor in january!!
If you havent read the article its worth a look but I can't say I was particularly impressed. It got me thinking though and so did some of the stuff on the treads so I have done a bit of digging.
First thing was that many people who sell anchors give very scant information although notable some of the 'new' manufacturers and a few chandles are better than most (congatulations to rocna and marinestore).
The second thing was that what was recommended was very different from what was recomended in Ian Nicolsons' Boat Data Book which I have used extensively in refitting the boat. Anchor sellers suggested 25-35lbs for main bower for general use whearas Nicolson recommends 50lbs for coasal or 2x 70lbs for long range!! (this is for a 32ft 6.5T sloop)
This was a starting piont, but in order to understand weather an anchor system was good enough I needed to know not just what pull it would hold but what pull the boat would put on it. The most valuable thing in the YM artical was the address for Alain Frayssee site which is at www.tinyurl.com/5goox and is outstanding, anyone going long distance or frequently anchoring should definatly read this.
Working from this data I worked out that for my boat In need the the anchor to resist the following (for 32ft 6.5 ton sloop) using 'traditional' anchors:
Up to F6 about 600kg, pretty much anything will do and 25lb with short chain and rope road would be fine
Up to F8 about 1400kg, the max recommended anchors at 35lbs is going to struggle unless the holding is exellent I need to go up to 45lb to be comfortable
For a true storm anchor capable of standing up to F10 the load goes up to 2582 and even the 45lb is not enough I need to go to tandom 45lb which are then good up to cat 1 hurricaine (5000kg at 70kn) at which piont the 10mm chain breaks!!! (This data is based on reserch published by the American ABYC but in fact assumes less conservative figures than they give as the ABYC covers any boat including cats which have much higer draf factors than my boat)
So my conclusion is that Nicholson is right in recommending at least 70lb anchors for long range cruising and what most people are advertising (eg 35lb CQR) for my boat is only correct for up to about F7, presumably you are supposed to get into the local marina if the forcast is worse than than - not helpful if you happen to be in the north of Scotland at the time.
The other recomendation is that I should be setting abot 5:1 scope of 10mm chain with a 15mx20mm link of good strechy rope as a 'shock cord' to stop snubbing - for 20m depth thats 100m chain weighing 225kg plus about 90lb (40kg) anchors, total 265kg or more than 1/4 ton and thats just bowers! I any case I would always opt for an all chain main rode because of the risk of rope chaffing but its a good job the boat is a good load carrier
If fact I can confim this works because the winter before last I left the boat on exatly tackle that while visiting me mum for christmass in Fishgaurd (there are no mooring you have to swing on the hook) and it blew force 10 for 2 days. I was fine but the 100ft seagoing tug moored next to me sank.
So am I tempted as the artical suggests to sell the CQR's. Well I have never had a problem with dragging and not on grounds of wt because most of the wt is in the rode and you still need that. But if the new style anchors realy do hold 5000lbs+ (which the tests do seem to show) then I would only need 1 and could set a second on the spare rode to allow for wind shift etc or if I lost an anchor. With my current setup I am only really equiped for up to F8 using a single 45Lb and keeping the other as the spare or layed out as a second anchor for wind shifts etc. If I tandom them I loose the backup and I cirtainly don't want to carry a a spare pair!!
What does anyone else think?
Whats you experience of anchoring in storm force winds and how did it work out?
