rustybarge
I'd build a acrylic hatch cover with 2" deep sides, should be enough to keep the green water out! If you google 'cnc machining' ( or diy Perspex fish tanks) you can get the persex cut to the exact spec at exactly 90 deg, and dovetail joints at the corners to make it super strong. The special glue makes the joint as strong as the original.
Then just make 2" high wooden coaming around the original cut out hole, to fit inside the Perspex hatch.Bonus: you can open hatch.
