The best way to clean lines and jack stays?
Nostrodamus
7 Mar 2011
www.cygnus3.com
What is the best way to clean the grime of the various lines?
I remember being told once not to use hot water as it can effect some lines but is it an old wife’s tale ( can some of you ask your old wife?)
Should you use any detergent?
Finally jack stays. Mine have faded over the year and is it best to renew them or is there a dye you can use that won’t run all over the decks when next they get wet?
AliM
24 Jun 2004
UK, Herts/Essex
We wash ours in the washing machine. Cool wash (30 C) normal washing powder. A hand wash should be fine, too. Opinions differ on whether to use a conditioner, so we don't, just in case it makes any difference.
Jackstays - if they've faded, are you confident that they have not deteriorated due to UV? The stitching is particularly vulnerable, and you do not want to find out that they have weakened at the point when you use them in anger!
I don't know the answer, but you may be more confident of their strength if you replace them.
TiggerToo
23 Aug 2005
UK
washing machine, on a synthetic (cool) programme.
Webbing jack-stays will be degraded by UV when left on deck. "Renewing" them by dyeing is not really a good idea. Once they start showing evidence of degradation (e.g. fibres fraying), I'd consider getting new ones.
PuffTheMagicDragon
I don't use the washing machine. Soak them well in a tub of fresh water, swirling them round so as to get rid of much of the accumulated salt. Do this over a couple of days. Lift them out and hang them to drip. Meanwhile refill the tub with fresh water and add washing powder (a couple of handfuls dissolved completely). Immerse the lines, swirling them as before and leave soaking for several days. The water will go black if your mooring is anywhere near traffic. Rinse well and hang out to dry.
In the case of sheets I do a further 'cycle' this time using conditioner instead of the washing powder, obtaining clean sheets that are soft to handle.
Tranona
10 Nov 2007
Answer for jackstays is to remove them when not at sea - which even for the most avid sailor is the majority of the time. Not only does it save them from UV by removes one of the sources of dirt on the deck.
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
If they are faded the thread and material will be damaged by UV and the jackstays will have lost strength. I'd suggest replacing them, that's what we do.
rob2
23 Aug 2005
Hampshire UK
I wash my ropes in the bath - warm water with washing powder. Leaving them overnight forces me to deal with them in the morning or I start to smell! Ideally rinse a couple of times and hang outside on the line in the rain. Fetch them in on a nice dry day.
Rob.
26 Nov 2009
everywhere
Bung them in the washing machine with normal detergent at 40C. Done if for 20 years and only once had a slight problem when I did it too hot and shrank my reefing lines a bit.
stownsend
15 Sep 2006
South Wales
Washing machine on 30 degree wash using natural soap flakes. Normal washing power and detergents will cause havoc to any lines and reduce their strength etc..
Cheers
Stu
VO5
14 Sep 2009
Gibraltar, RGYC.
Additionall as a footnote to all the above posts:~
Stranded rope can also be washed in the washing machine with detergent and warm water etc., but don't forget to inspect the ends before you do so.
Make doubly sure the whippings / splices at the ends are absolutely secure, otherwise they WILL unravel. This is irrespective of whether you choose to put them in a pillowcas or not.:eek:
ffiill
5 Sep 2007
Yes take it from me webbing disintegrates!
ffiill
5 Sep 2007
Beware with acrylic sail covers and like-often get mouldy and I once had a go with some zip in side screens-turned the heat up and they came out spotless and about and inch smaller-I had to remove and resew all the zips!
mcframe
9 Dec 2004
London
<ahem>
Chuck 'em in the bottom of the bath (also used as domestic shower) for a couple of days, leaving the plug in betweentimes ;->
DanTribe
8 Jan 2002
Essex
Fill the dinghy on the quayside, with fresh water and detergent? Then swill everything around in it like your granny on wash day.
We bought our granny a shower.
It's not very kind to swill her about in a dinghy in full view of the passers by.
