Refueler
Screw shop came up trumps ... not exactly same as originals as the thread type is old hat ... so I replaced every other fastening ...
All good and back together.
With the double sided foam does one side stick to the hull, and the new lining to the other side, without the need for more adhesive?No give it 5 to 7 years and will start disintegrating again. Believe me this is from bitter experience.
Mine has now all been re done with double sided stickey back foam from Hawkhouse. Made from a totally different material that does not fall apart...
that's the way I was thinking of going.laminate floor underlay foam sheet
Think that's actually what we usedthat's the way I was thinking of going.
Yes that is how you use it - no glue required.With the double sided foam does one side stick to the hull, and the new lining to the other side, without the need for more adhesive?
Was thinking of using Hawkehouse single sided. foam then sticking the new lining to that with spray adhesive.
If you PM me I have lots of photos
Thank you, just sent a PM.Yes that is how you use it - no glue required.
