gregcope
So daughter and I go aboard to motor to a local anchorage for the evening.
The house bank is just over seven years old and mostly dead. It could not start the engine. I know it has virtually no capacity (15Ah from a 240Ah bank) and needs replacing. However replacement did not seem urgent.
Whilst motoring i was surprised that the alternator was putting 35A into the batteries, yet the voltage was still only 12.5V and looked like it was falling. “Hum” i was thinking. Did i leave something on last time as the batteries were flat? We have solar panels that should have kept them charged. At the time it seemed they were flat and needed a charge.
When we anchored and stopped going down below there was a foul smell. Within a few seconds I twigged. I checked the batteries and one of the house bank was very hot and burbling.
I hurriedly disconnected them and removed the suspect one to the deck and reconnected the okay one whilst opening all the hatches and then sitting in the cockpit… as the smell was most probably hydrogen sulphide
Moral of story…
1. Replace batteries when you think they have died …
2. Have an easier way to disconnect in a hurry. Anderson SB175s come to mind. Fiddling around with multiple battery connections whilst avoiding a short could be avoided.
3. I have a few things directly connected (vhf, bilge pump, chargers) to first house battery. These should probably be on a busbar with a way to switch them.
4. When you have abnormal voltage/amperage that does not make sense check the batteries. This could have got serious if we motored longer.
After all the excitement the anchorage was lovely. We did not use the batteries.
Moral of story…
