eebygum
My boat came with a Shipmate external speaker which is wired through to the Nav station but is not connected to anything as I removed the old non-functioning Shipmate VHF.
Is there a quick test I can do with a multimeter (please assume I know nothing about how to use obe) to test it is working BEFORE I go to the trouble of wiring it up to my Cobra Marine MR F57 fixed mount VHF.
I can see from the Cobra manual that it has external speaker outputs… a +Positive and - Negative connection. Do I need to know which is which from the external speaker or can I connect up either way.
If the external speaker works, and I connect it correctly…. Will it always be ‘ON’ or can I toggle or add a switch to make the fixed VHF speaker the primary ?
I’m working on the boat in Bangor for the next two days so any help/suggestions appreciated as I will try them out while I’m down on the boat.
Cheers,
Cheers,
