pcatterall
Here's a picture of my new lift pump. The one on the engine would not work so I took it off and tried it as per the photo it wouldn't work so I got a new one.
The new one also does not work and I am scratching my head again.
It is connected to the 'in' port so I would expect that operating the priming lever or the 'internal arm' should eventually get fuel flowing from the 'out' port.
I tried starting it off with a rubber bulb and forced fuel into the pump but subsequent hand pumping would not force any more fuel out.
The diaphragm seems to be flexing as it should and I am stuck for ideas.
Any suggestions please?
yes, I will be fitting an electric pump as a primer/emergency pump but want to keep the mechanical one for normal use.
