coopec
N/A
I use my ½ inch router upside down in a router table. I hadn't used it for about two years but when I switched it on it seemed to struggle and made a noise as if the bearing was slightly seized. I gave the collet bearing a squirt of WD40 and now it won't work at all.
Before I toss the router out I want to do a series of tests with the multimeter. I can't get to the copper of the cables so I was thinking of poking pins through the plastic insulation and testing (very carefully) before and after the ON/OFF switch and also if I'm getting power to the variable speed control (before /after)
Is there any way I can check if the field windings are stuffed? I've checked to see if the brushes are OK and not surprisingly they are (the router hasn't done much work)
Are there any other tests I should do before I toss the router in the re-cyle bin?
