IanR
After taking possession of the new to us boat, we took down the mast and replaced all of the standing rigging and mast wiring including putting up a new aerial cable and a hawk aerial. On refitting the mast I cannot get the VHF to transmit reliably and reception is weak.
I believe it was acceptable prior to mast removal, although this is hearsay as prepurchase.
So the troubleshooting initially defaulted to refitting the mast connector at the base which I made good thinking it was the most likely candidate.
I even went and purchased a new set of gold hyper expensive connectors , no improvement
I then swapped the DSC radio just in case with a spare I was selling (belt n braces) no change
I am now left to believe that the new cable or the connection at the top of the mast or the antenna itself could be faulty.
Given that I do not have an SW meter is there anything else I can do to diagnose without shinning the mast? Even if I got hold of a meter would it help?
I have not changed the under deck cable yet , the mast head cable to the aerial is pre made by the manufacturer and connected by the yard crane operative.
Any thoughts or tests gratefully received.
