Swanrad2
Hi, I am doing a first start on our MD11C this weekend having done a lot of work. I suspect the engine stop won't work (or at least have to proceed as though it won't due to earlier issues - but I won't know until after it has started) so I need a plan B to stop the thing. I checked out the space between my head and the flywheel at the weekend with a view to using the 'cracking off the injectors' method - and it was a little tight for me. This is, therefore, now plan C.
So plan B is a plank with two caps screwed to it that will be placed over the air filter housings to starve the engine of air if it won't stop. The caps are a decently tight fit, I can squeeze in a bead of silicone and let it set if needed and be pretty confident it won't get sucked into the engine...
Anything else need doing to perfect plan B, with a view to avoiding Pan C. Or is I all a terrible idea and here is plan D?
