D
Deleted member 36384
There is a hint in this thread that somehow the leisure sailing industry is negligent or ignorant in designing safety equipment to keep a person on onboard. In my own industry, drilling oil wells, I have seen the evolution of fall protection gear since 1990. When I joined a drill crew we used 'belly busters', 'man riding' and safety harnesses that were constructed of 2" wide webbing, big buckles with limited adjustment options, braided steel wire encased in plastic that rusted; the harness / lanyards actually contributed to killing you should you fall from height. There was no control over quality and maintenance consisted of jet washing the canvas fabric. It was the personal opinion of the Toolpusher that decided when the harness / belt was worn out. There were times when I had to climb the derrick, move along the girders and tie back or fit equipment; I tied on when I got to the area I had to work as the safety lanyard was a single hook. If I fell there was a high probability that if it took longer than 20 minutes I would die as a result of reduced blood flow. It took a couple of deaths from this and paralysis from falls being arrested rapidly for the industry to react.
Today we eliminate all man riding (lifting in a bosuns chair type device) by designing derricks with good access. The harnesses are designed to be fully adjustable, they have rescue loops that can be dropped down so that the suspended person can put their feet in and stand up to take pressure off the groin area and maintain good blood circulation. The tethers are designed to stretch at a rate that decelerates the fall velocity at a safe rate, positive indication devices of overloading or fall restraint action, the hooks have one handed double acting locks, everything has a unique serial numbers and traceable to a QA technician and have a dispose by date, many drilling companies only allow personnel who have completed practical training to use a harness and work at height. Despite this, last year the industry had a general recall of a manufacturers product when it was discovered that the ladder climbing device could fail in the open position and not stop a fall. Self Retracting Lanyards (SRLs) are hung from areas where working at height happens regularly e.g. above equipment and typically extend over 30m: some snap to a halt and some limit the fall speed to a maximum and some decelerate a fall to zero velocity. There are many other aspects around working at height that have been addressed.
My point is that a highly regulated industry has taken many years to come up with safe working practises and equipment associated with falls from height. I see no reason why the leisure industry would act any different. Of course, now that there are fatalities it may force a change if consumers demand it and are prepared to pay for it.
