Temporarily filling fixing holes
penberth3
9 Jun 2017
Hi
We've just bought, and are doing up, a Copland Fox Terrier 22. We've removed all the deck fittings for restoration and just want a quick and easy way to fill the holes over the winter to keep water out. I was thinking just a bit of DIY decorator's caulk? I reckon it'll keep the water out but also just poke out easily when we want to re-fit cleats etc.
Any other ideas?
Just to clarify, are these blind holes or through holes, or both?
WoodyP
18 Aug 2004
West Wales
No need to go to the expense of building a tent. Just sheet it down with polyprop tarpaulins. It will keep the weather out and quick and easy to remove when you have time and the right conditions to do a bit of work.
zoidberg
12 Nov 2016
For the task of filling old fittings' holes, I've simply squirted some CT1 in using the provided tapered nozzle. That's intended to be a temporary fix, for a few months.
For a boat covering, I built a framework from MDPE pipe ( arched over between stanchions ) and builders' uPVC 100mm pipe ( as ridge ), using multiple reusable cable ties. Ordinary polythene sheeting works, but only for a while then splits. I 'upgraded' to green polythene tarpaulins ( eBay, Amazon ) which have proved satisfactory over several winters.
White translucent mesh-reinforced poly sheeting would be better still.
