Temp. fit of transducer.
single
19 May 2012
Cardiff Bay
So, i want to make sure this new transducer works through the hull before fully fitting it.What material can i use that won't make a mess and i can move about to find a good position? Would plasticine or putty or playdough work?
VicS
13 Jul 2002
or Blu tak
Plastic bag of water is said to work.
A silicone implant ?????
Bikerwookie
3 Feb 2013
Use plumbers mate. Once position is decided the plumbers mate can be used to make a dam to pour resin tinto for a permanent solution.
Seajet
23 Sep 2010
West Sussex / Hants
After taking advice from these forums I fitted a fishfinder transducer ( transom type ) inside the hull with standard silicone sealant - works a treat and easily moved if necessary.
Not heard of this being done with the conventional disc on a threaded rod type transducers though.
oldsaltoz
4 Jul 2001
Australia, East coast.
To find the best location, half fill a plastic bag with water, wet the area you want to test and slide the bag with transducer submerged to get a reading, the wet floor is eliminate any air between the transducer, plastic bag and the hull. Look for bags with seam on the bottom.
When fixing take great care not to trap any air or the thing won't work.
You could also mount the transducer in a box or cylinder so that it can swing and give the correct depth when heeled. just top the container up with a bit of oil, almost any type works.
Good luck and fair winds. :)
SteveTibbetts
19 May 2008
Me - Brum , Boat - Porthmadog
I used sikaflex as a temporary fixing. Realized that I might as well leave it in place when I saw the sounder was working better on this boat with a temporary fix than on previous with an elaboratly manufactured oil bath. (A big 'transom fix' sounder that comes with a Garmin 's' series plotter)
single
19 May 2012
Cardiff Bay
Why with the seam at the bottom?
