pmagowan
Forest grown teak is still available but it is essentially illegal and has had its stamps altered in order to remove it from protected woodland. Probably not a good idea to buy it due to the destruction left in its wake. I think old teak certainly was of a better quality and the same applies to other hard woods like mahogany which are now plantation grown. A lot more of the wood is pith and it is cut in such a way to get maximum revenue with minimum waste rather than originally when the quality of the product was paramount and the waste was a necessary evil. I don't see anything wrong with glassed decks as the plywood substrate is the structural element and being very stable will have virtually no give. In fact, for the ribs a traditional deck is more problematic as the longitudinal timbers will expand at right angles to the grain and put pressure on the structure. It is only taken up by loose caulking which allows some give but also makes the inhabitants wet. With glassed ply there will be essentially no movement and so the boat should remain unchanged throughout its life, The ribs and planking are not thick and so will have minimal effect. My plan would be to attach the new teak with sticky stuff rather than mechanical fixings. This gets the benefit of both worlds with a waterproof substrate and a teak deck with room for expansion and contraction.
