Taxing Gas Question
Trevor_swfyc
19 Jan 2002
Crouch
Gas is being used a lot more in boats now that it is becoming more readily available, but can the same gas be used in a road vehicle from a tax point of view.
Trevor
Pete735
13 Nov 2004
South Wales
If you are talking about LPG, then yes, I have been using it in my car for 3 years now. Not sure about the tax question, though, I have always assumed that unless used for heating, lpg picks up duty just like petrol.
Evadne
27 Feb 2003
Hampshire, UK
I think the answer\'s yes
As I understand it, LPG in cars doesn't attract road tax, which is why it is cheaper than diesel. It is also the obvious replacement fuel for big MoBos if and when red diesel comes to an end. You could always search HMCE site <A target="_blank" HREF=http://www.hmce.gov.uk/channelsPortalWebApp/channelsPortalWebApp.portal> here </A> if you've a spare hour.
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Re: I think the answer\'s yes
Didn't I hear somewhere that you can run diesels on cooking oil? Seem to remember a stroy about a chip shop owner running his car on the old oil.
mikewilkes
28 Jul 2001
North Moray Coast.
Safeway do a good trade in North Scotland on cooking oil - allegedly......
bluevelvet
15 Jul 2002
Scotland/Clyde
LPG can be used in your car and if you buy it from a garage their is a road duty tax built in.However if you used boat or heating gas the tax man says you should notify him of your useage.Car use of LPG is increasing greatly due to the high price of oil and LPG is also creeping up but for the forseeable it will remain at less than half the price of petrol.I have been useing gas cars for over five years and would not consisder going back.Regards John
bedouin
Yes you can run diesels on cooking oil, but in order to do so legally on the road you need to pay tax! The levels are much lower than on diesel but you still have to pay /forums/images/icons/frown.gif
Evadne
27 Feb 2003
Hampshire, UK
There was even a TV program on it. You have to treat the oil (add oil and paraffin I suspect) and then declare how much you've made to HM customs so they can charge you tax. It's still cheaper even after that, allegedly, and I believe there are some people making a living out of manufacturing and selling the stuff. If you think you can get away without anyone noticing, though, just try standing downwind of anyone using old chip oil and take a sniff.....
Evadne
27 Feb 2003
Hampshire, UK
richardandtracy
27 Jun 2002
Medway, UK
Don\'t forget charcoal, wood, coke..
It's also possible to make 'producer gas' from a large number of organic substances. This stuff will run in petrol motors given the right carburation. Take a look at:-
http://www.lindsaybks.com/bks7/bchar/index.html
However, if you do follow this route don't blame me if the engine gets wrecked in short order!
Regards
Richard.
boomerangben
24 Jul 2003
Isle of Lewis
Re: Don\'t forget charcoal, wood, coke..
As far as I know, cars run on Propane and cookers and heaters on boats run on butane and I am not sure that the two are interchangable. Both are LPG, but propane comes in red bottles, butane in blue.
Talbot
23 Aug 2003
Brighton, UK
propane freezes at a lower temperature than butane. Thus liveaboards have been using propane for a long time. The standard regulator is normally butane only, although some from Gaslow will cope with both (and with camping gas which is also butane) I suspect that butane is slightly cheaper which is why it is the gas of choice for most in boats and caravans
mirabriani
17 Mar 2004
tite stops your nuts falling off
This subject has (of course) come up before.
See http:/www.veggiepower.org.uk/page208htm
Sorry I cannot yet do links
There is a group called Low-Impact Living Initiative (LILI)
Who have a series of information about such things, including;
make your own wind powered generator, wood stoves,
solar power etc. LILI are at www.lowimpact.org
Regards Briani
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
I have had my engine running on the doughnut oil for a while now, bought it online.
Make for a very nice smelling exhaust and the engine will never have any more carbon in it which is reflected in the oil which is now clean at all times.
The fuel tank has to be cleaned before starting to use it though as the new fuel disolves all the rubbish in the tank and blocks up the filters solid.
steve
huldah
31 May 2004
Bath UK
Propane freezes at a lower temperature than butane, however butane is said to have higher heat potential.
Trevor_swfyc
19 Jan 2002
Crouch
Dave,
Thanks found the information but as you said its at bit long winded, but it appears that as long as the LPG tank clearly states that the gas is road tax paid it is ok to use it in a road vehicle. They give a list of tax exceptions one being gas used for heating so I deduce it would be illegal to use the gas from a tank that supplies a heating system. We all know that red diesel contains not only a dye but also a marker chemical so if they catch you with marked diesel in your road vehicle you are in big trouble, but what about gas is that marked in any way? or would they ask to see my receipt and if I couldn't produce it deduce I was guilty.
Trevor
Andrew_Fanner
13 Mar 2002
ked into poverty by children
Naturally, however, once the LPG use reaches a "critical mass" (which Gordon has almost certainly calculated) it will be declared subject to tax at pretty much the same whack as petrol/diesel. After all, in the early 90's IIRC the difference between petrol and diesel was of the order of 15-20 ppl whic was a big incentive to buy our first diesel car, cheaper fuel and more mpg.
<hr width=100% size=1>Two beers please, my friend is paying.
