martin
Hi,
My p45 seems to have an intermittent problem on the flybridge Port throttle. It works fine usually but at ramdom moments (usually the most scary time possible) it drops offline and returned the engine to idle (1000RPM). The error message it gives is 2.7. I looked this up in the manual and it pointed to a problem with the potentiometer in the throttle control. So I tried replacing the whole throttle unit. Same thing happened!.
Have now researched on web and seen post from Aviator (and others) on similar problems (have PM's him) but no fix stated. Desperation now setting in as annual hols starting at the end of the week and would like to get it fixed...Any ideas?
BTW have checked the wiring and added many cable ties etc..still happens?
