boatmike
I have done a lot of work on my two TMD41a engines which are now fitted with new ZF gearboxes, shafts and props. I have also had both turbos professionally reconditioned, cleaned out both fuel tanks and fitted new filters. The Stbd engine runs fine and gets up to 3600RPM with 1 bar positive manifold pressure. The Port engine is down on power and only gets up to 3200RPM with about 0.7 bar positive manifold pressure. It also blows quite a significant amount of oil out of the crankcase breather. I am assuming that having got everything else right that the extra manifold pressure and higher revs has now exposed a more fundamental problem with the engine and thought at first that it must be busted piston rings. However it dawned on me that a head gasket failure could be the cause also blowing between a cylinder and an oil passage. In fact possibly more likely as there is a lot of oil blowing out indicating a crankcase pressure that is quite high when running at high revs when the turbo cuts in but not at less than 2000RPM . Does anyone on the forum have experience of a similar failure with this series of engine?? Looking at the workshop manual the oil passages are very near the cylinder and I am wondering if its a common problem? ps They are TMD41a not TAMD41a but I can't seem to edit title.
