Symmetric spinnaker, subtle differences in design
Channel Sailor
5 Mar 2009
Portsmouth (UK)
I have two spinnakers that came with my yacht the newer one which I use all the time, except once when I hoisted the much older one just to see if it was OK. But it was not up for long. At a glance I think one is possibly very slightly larger and may have a deeper belly to it. My question is, if I can find space to spread the two of them out or even suspend them, what am I looking for to understand if they have different uses? In particular which one would perform better if set shy.
Reason for asking is I want master setting a spinnaker on a reach and how close to the wind it will go. So I need to understand if I have a sail that will do it in the first place, before I waste time only to later find out I need a new sail anyway.
It's the flying shape that matters, you won't see that spread out on the lawn.
I'd suggest putting the two kites up in turn and maybe taking some photos.
A flatter sail will go closer to the wind, but there are no magic angles, the angle you can carry a certain kite to will vary with windstrength.
Very often is possibler to carry a kite on a tight-ish reach, but it won't do you any good, just heels the boat and stretches the kite.
What cuts are the kites?
A simple horizontal or radial head is likely to go less close than a star cut. But that may not be a reliable guide.
Depth and size of shoulders is the key. A broad shouldered deep kite will run well but not reach. A relatively triangular kite will reach much better but is giving up area on a run.
Useful, thank you. One of the spinnakers I think does have quite noticeable broad shoulders, the one I use mostly and it does not seem to set all that easily on a reach, so far. I will look more closely. Noted the point about setting shy can stretch the sail, as I have already noticed in a good sailing wind the dramatic increase in apparent wind and heeling which when wind is too far fwd the sail (and rig) gets a hammering.
From my singlehanded tips book regarding a deeper spinnaker versus a flat spinnaker, specifically in regards to what would be designed for a singlehanded sailor:
I contacted Rick McBride with Leitch and McBride Custom Sailmakers in Sidney, British Columbia. Rick explained the differences between a stable and a flat spinnaker. The skipper should keep in mind that all spinnakers act like a wing, with air flow from the luff to the leech, even when sailing deep downwind.
A stable spinnaker is designed to be used with minimal attention to sail trim. It will fly even as the apparent wind oscillates back and forth in normal conditions. A flat spinnaker, in contrast, requires constant trimming or will collapse. A stable spinnaker has greater cord depth. This allows the boat to sail higher or lower without the sail stalling. It also has a more elliptical leech, allowing the luff to fold over on itself without collapsing. A flat sail will collapse if the leading edge folds over at all.
Like the wings in a jet airplane, a flat spinnaker is faster but is more prone to stalling or collapsing than a stable spinnaker designed for singlehanding. This tradeoff between speed and stability depends on how much the skipper is able to work the sheets over hours at a time. The accompanying drawings are highly exaggerated. In reality a stable spinnaker has a cord depth only a few percent greater than a flat chute.
To tell the difference in spinnakers on the floor you look at the half width vs foot length.
Approximately a reaching spinnaker will have a half width less than the foot while a running spinnaker will have a half width bigger than the foot.
To find the half width take the head down to each clew and mark halfway on each leech and then measure across.
http://www.sailing.org/tools/documents/ERS20172020UpdatedPrintVersion-[20912].pdf Measurments found on page 35.
