dt4134
You know, these posts just reinforce my view that the old-fashioned 1-2-Both switch has no place on a boat in the 21st century! It was introduced by boatbuilders in years gone by as the cheapest possible way of providing the ability to isolate a starting battery and allow charging of a second battery.
But the inherent problem with a 1-2-Both switch is that it's far too easy for the switch to be turned to the wrong position (or left in the wrong position). Apart from blowing the diodes in the alternator, the real danger is that using domestic electricity will flatten the start battery if the switch is left in the wrong position. Today, there are much better and simpler solutions which offer no chance of getting it wrong!
The easiest solution is to have two simple on/off switches - one for the start battery, one for the domestic batteries. The alternator feeds the start battery. When the engine's running, a VSR automatically connects the charge to the domestic batteries. When the engine stops, the VSR automatically disconnects, isolating the domestic batteries. There's nothing to go wrong. When you arrive at the boat, turn on the 2 switches; when you leave the boat, turn off the 2 switches. VSRs are incredibly reliable, so there's no reason not to use one.
Some people fit a third switch, to connect the domestic batteries to the start battery if the start battery is found to be flat. However, it isn't necessary really, because with the set-up I've described the start battery shouldn't ever get discharged.
I'm of pretty much the same opinion. If in the future I buy a boat with a 1-2-both switch it'll be one of the first things I'll replace.
For a start, the requirements for a battery to start the engine are very different from the requirements of a domestic battery or batteries.
I've two circuits, one with an engine starter battery connected to the starter (surprisingly enough) with its own isolation switch.
The second circuit connects the domestic battery bank to the domestic load, again with its own isolator switch.
I've an isolator switch that allows the domestic to be used to start the engine. This would normally be done with the starter battery isolated. I'm most likely to be using the domestic to start the engine when the starter battery has serious problems, so most likely it would be counter-productive to include it in the circuit. However, just in case, I've got it set up so both can connect to the starter. Haven't had to do either since I got the above properly set up.
I also use an alternator to battery charger (Sterling) to charge the batteries directly. Not cheap but I reckon it'll pay for itself eventually by extending the life of my batteries.
A big advantage is that if some confused crew member accidentally turns any switch to off all you need to do is turn it back on. No smoke. No sparks.
