sigma38dave
Lots of good advice above. I always swim down and check the state of the chain and ground tackle on unknown moorings too.
Just takes a bit of practice. The Exe estuary can have a few knots running and if you have never been aground in the estury then you are lucky (or more likely not telling the truth).I am always impressed with how simple you all make it sound. Minimal tide / wind in your world and moorings which have no shallows or other boats around to drift in to! The OP’s approach has essentially worked for me in the past - not always first time. An escape plan is essential.
I motor up to the pick-up buoy, when level with the cockpit pick it up and walk forward as the boat falls back on the tide. Just a matter pulling until the eye of the mooring can be placed over the cleat.
Been there, done that: moored by the keel. Now try to never let the buoy go aft of the (deep bulbed) keel. I'm really not THAT bad a boat handler, but once the wind gets up singlehanded on a modern 35-footer I can sometimes take several goes to walk forward (at my age I don't sprint) and get the pickup buoy aboard before the bow blows off one way or an another.I've always refrained from doing that.
I must admit I'm a bit paranoid about not being able to pick up the mooring in time and the buoy passing under the boat and possible getting caught on the keel or prop.
The one I pick up when solo is a club mooring in the Solent, near Yarmouth pier head. Not short of tide or wind, and far from always co operative. It takes me less than 5 seconds to get the pickup with the boathook, from leaving the helm, and maybe another 5 to put the loop over a bow cleat. I wouldn’t attempt it on a strong flood tide and a NE wind, but any other condition I’d consider leaving the harbour in is fine. Even our light, flighty boat doesn’t do much in 5 seconds. I do get to put the pickup between the hull and the outrigger, in front of the front beam, which I suppose gives me options of where to grab it from. I do get some practice though, the XOD moorings are just inside the cruiser ones. Every time we sail we have to sail back onto a mooring. Use makes master, I suppose. I haven’t tried sailing the tri onto that mooring mind you. I have a feeling there'd be tears before tea time…I am always impressed with how simple you all make it sound. Minimal tide / wind in your world and moorings which have no shallows or other boats around to drift in to! The OP’s approach has essentially worked for me in the past - not always first time. An escape plan is essential.
The hybrid approach, taking account of both wind snd tide is the key to success. Our club moorings have ‘Marksman’ the clubs big RIB, which seems to have the same characteristics as us. Line up with that and it’ll be a job well done. Pick a neighbouring boat like your own.Approaching my mooring I check how the neighbouring boats are lying as wind +/- tide means 'head to wind' isn't always the correct approach.
Always pull the pick-up line with the boathook rather then use it as a lever to get the line on board. And if it's a telescopic boathook make damn sure it's screwed together securely. And carry a spare boathook. In case you, or a crew member, forget either of those tips.
Sounds like that wouldn't work for the OP as the moorings are so tightly packed together, with extra rope might hit boat behind.I used to have a line cleated at the bow and running back to the cockpit, outside the guard rails, with a big carabiner on the end. I'd pick up either the buoy or the short floating grab-rope from the cockpit and clip on the carabiner (the grab rope had a loop on the end).
At that point I was attached securely and could relax, engine off or into neutral (or drop sails if I'd sailed in), then head forwards and haul the thing in.
This was single-handing a small, lively boat in a very tidal river so it didn't do to walk away from the helm without being secured to something!
That’s exactly what I do!My home mooring has a floating pickup line with a loop on the end.
I attach a line to the bow long enough to reach the cockpit that has a large snap hook on it.
I just motor along side, head to wind, by the cockpit and pick it up and clip it on. Then reverse back a bit, walk forward and pull it in.
The buoy is always visible to me and I don't have to leave the helm until attached. No chance of any mishaps.
Rope goes forward from the cockpit to a block on the bow then back along the outside to the shackle/clip.Sounds like that wouldn't work for the OP as the moorings are so tightly packed together, with extra rope might hit boat behind.
Re bow blowing off, putting the bow just to windward (ie not going head on to wind) can help as bow blows down onto buoy as walk forward.
Well all good theory, just heading in to look for a visitor mooring so let's hope my solo efforts dont fail![]()
It can involve a bit of luck, especially if the tide is uncooperative, but basically it’s a matter of letting the bow blow off but in the direction of your choice, bringing your boat onto the buoy at just the right point to pick it up easily, perhaps.I wrote above about problems with the bow blowing off before I could get from cockpit to the bow. My previous boat was a heavy long-keeler with hank on sails, and picking up a buoy was really easy - the boat more or less stayed put in the water once stopped.
Now with a modern fin-keeler with a rolled genoa for extra windage forward, and a really narrow keel, the bow blows off really fast. On my mooring, if I went forward far enough to get the mooring buoy level with the cockpit I would hit the boat on the next windward mooring. They are really spaced pretty tightly.
I manage, but bow pickup sometimes takes 2 or 3 goes if singlehanded, and if really windy backing up to the mooring under engine is pretty much the only way. With a crew it's easy, power up to the mooring and stop with a good burst astern as soon as the crew has the pickup buoy in hand.
An update. So stopped at buoy, walked forward and hooked pickup buoy first time. Good so far,Sounds like that wouldn't work for the OP as the moorings are so tightly packed together, with extra rope might hit boat behind.
You are the worse type of visitor. Quite happy to damage the mooring and complain about the price. TypicalI have a length of 14mm polyester with 1m of 6mm chain spliced in the middle. Loop on one end of the rope, onto boat cleat. The rope with chain is easily thrown to lasso the mooring buoy, and the chain sinks it, so as to give chain on chain, underneath the buoy. Use from aft/midships if singlehanding.
1m of chain is sufficient to take the chafe, chain on chain, and not abrade the buoy.
I use this when providers of invariably overpriced "visitors moorings" are too mean/inconsiderate to provide any form of pickup buoys. Some authorities hereabouts even top their "hippo type" visitors moorings with small D shackles, rather than larger bows, seemingly to make life that bit more "sporty" for visitors?
No risk of loosing your fancy buoy catcher boat hook etc, especially if you are only carrying one...as I now know...
Once secure to buoy chain, I can then work a rope or chain thru the central buoy top shackle at my leisure.
Made my own from an old danbouy. Perfect, nose the bow up to it and lift it aboard with ease. I've got an old Primrose Moody with a very high flared bow, couldn't manage any other way single handed. The Treharne version looks good a bit pricey compared to a cheap Jimmy Green danbouy.Has anyone tried one of these ... Stand-Up Buoys | Treharne Moorings
