S04
Plumber's mait?
Doesn't harden or shrink, is waterproof, non sticky and can easily be removed and reused.
Thank you. My only concern would be how easy it would be to remove in the future. The description states "In 12–24 hours, it turns into a strong and durable silicone rubber that stays stuck."That’s why I suggested Sugru in post #2. Buy some and try it
It seems to me that high density foam might be the best way ahead.
Much easier than Sikaflex in my experienceThank you. My only concern would be how easy it would be to remove in the future. The description states "In 12–24 hours, it turns into a strong and durable silicone rubber that stays stuck."
The electrical connections from my mast (wind instrument, VHF aerial, lights) are all badly corroded where they connect to through-deck plugs & sockets. I'm considering switching to a swan neck fitting to do away with exposed connectors so that I can run all of the cables through the one port & connect them inboard.
I've seen a few suggestions for waterproofing the end of the swan neck ranging from sponge to plasticine. Any good solutions to stopping breaking wave / moisture ingress and has anyone experienced any electrical interference by running multiple cables through the one port?
Should be ok. If it works flat then why not at an angle? Talk to the makers.https://www.svb24.com/en/stainless-steel-deck-cable-port.html
How will this fare with the angled base I have .. see my previous post #23 .....
It would be difficult to move to a ;evel horizontal location due to cockpit led lines etc. and then still be able to connect cables ...
It'll still work, but its effective height is reduced, making it not so good. Is there any reason why the bottom of the tube has to be perpendicular to the angled base?Here's a question related to Swan Necks that I think not only myself may like answer for :
My cable entry was made to port side of mast base where the base has an angled rise of approx 45 deg + from horizontal .. maybe mre. If a Swan Neck is is fitted to that hole already existing - would the angle compromise the neck form of the item ...
I have self tacker right next to mast front and also solar panel ...You place it on the deck, no need for it to be on the mast base, then run the cables in a neat run from the mast outlet to the deck. My installation is at the back of the mast, with cables from each side of the mast looping round and into the transit. In your case, not knowing your boat, in front of the mast might be an option. Equally, your boat may be unsuitable for this type of transit.
If you are making it yourself, or having it made for you, it can be whatever height you want.I would think that the tube if not 90 to the base would then have a very low section one side ?
Posh Dorade port?Stainless Steel Deck Cable Port
The stainless steel cable port/dorade box would not work well mounted at 45°. There is insufficient height to make up for the angled orientation.Here's a question related to Swan Necks that I think not only myself may like answer for :
Its base could be cut so it rises vertically.A swan neck would still work but with decreased effective height
Despite what the advert says,not a new design,but it is a very good one.You have this back to front, instead of thinking about sealing a swan neck, think about the best type of transit. I use the Stainless Steel Deck Cable Port, as per the link. This is a great bit of kit, completed water proof, snag free, can be stood on, and takes many cables through a large hole in the middle. All my cables, including a VHF cable and plug, terminate under the deck, above the head lining in a dry, warm environment. The cables can enter from each side, where there are two foam strips to keep the bugs out and provide a water resistant baffle. The centre, inside is like a dorado box, with a high side around the hole that the cables go through. When I need to remove the mast, undo the connectors below the deck, unscrew the VHF connector be.ow deck, unscrew the lid on the cable port and they all come out easily, with no hassle or strain. I sail in all sorts of weather and have shipped a fair amount of water over my deck, bone dry, over 10 years now in use. All the old deck glands around the mast were removed and the holes filled with Epoxy.
Honestly, worth every penny and superior to a swan neck in every way, and beats deck glands hands down. Thoroughly recommended. My next project will be solar panels on the quarter and I will replace a couple of crappy deck glands on the stern deck with the Stainless Steel Deck Cable Port to take the solar panel wires and others below deck. Very neat.
