Ludd
The Irish report on the sinking of the Hanse 371 (which had an aluminium rudder stock, the same as Bavarias). The rudder was designed and manufactured to ABS rules by Jefa a well known supplier to the yacht industry.There was no suggestion the failure was due to design. It failed above the bearings and the rudder and stock fell out. The failure was above the waterline so water entered and slowly sank the boat.
The maths in the ABS standard are a bit beyond me but they do of course take into account forces applied to the rudder. The boat was a sailing school and charter boat and had crossed the Atlantic more than once and the owner expressed complete confidence in its performance.
The natural assumption is that such rudders will fail where the stock exits the hull, either because that is the point of highest load, or as Charles points out a stress point at a machined radius - a potential issue in the Hanse rudder. However this was not the case, although it does seem to be the possible location of failures of Hunter rudders.
One of the difficulties with this subject is that there is very little clear independent information available. The reports I have seen of the Hunter rudders, including photos seem to show failure due to twisting and perhaps failure of the laminate rather than a clean break. The number of failures does seem high, and the apparent change in specification suggests the builder recognises this. On the other hand, once you get away from race boats there seems to be little evidence that spade rudders fail in the way one intuitively thinks they ought to.
But fail they do, and I cannot but remember the RNLI coxswain who.after the Fastnet disaster described such rudders as "unseamanlike". IMHO any rudder should at least be skeg mounted.
