Tranona
I wonder about the use of these high teck materials for the huge spade rudders. Same also goes for the use of Aluminium stocks, as in Hanse yachts. The problems with Carbon composites, is that they don't bend or give warning of breakasge - if they are going to break, they break. Presumably they are much more prone to failing under a shock load as there is no give in the structure?
As for Aluminium, I think that this is asking for trouble, especially if marina based with stray currents. You won't know you have a problem, and there is an arguement for dropping the rudder out every year to inspect the area hidden inside the hull and bearings.
I would prefer an massively over engineered S/S stock.
You may care to read the MCIB report on the Hanse rudder that failed in the Irish Sea. Despite extensive testing of the rudder (it was recovered after the sinking) by a specialist firm they were unable to determine the cause of failure. The sinking was due to water ingress because the rudder dropped out, not because of damage to the hull but because it was not in an area separate from the rest of the hull.
The rudder was made by Jefa, a Danish company which is a major supplier to European boatbuilders and was designed to ABS standards. It was aluminium of an appropriate grade. Both aluminium and Stainless are commonly used in this application - the former being lighter and I guess cheaper. However, there is not a history of failure of either materials in spade rudders as is noted in the report. This faillure seems to be the only one that has been thouroughly investigated, perhaps because it resulted in a high profile rescue. As also noted in the report, aluminium stocks can suffer from corrosion where the stock goes into the tube, particularly if antifoul is applied in this area. There are frequent reports of build up of deposits and surface corrosion in this area on Bavaria rudders leading to stiff steering, but dropping the rudder and cleaning seems to resolve it. However, when I checked mine after 7 years - 9 months in the water each year it was clean.
As to composites. They do fail by shattering. However, although there have been cases of failure in racing boats it does not seem an issue in production boats such as some of the Firsts. Like many others here I am suspicious of GRP tubes as stocks, and if the number of failures reported by Hunter is true - then I think they should reconsider their policy!
Coming from a long keel attached rudder background I was sceptical about spade rudders, particularly as some of the early attempts at skeg hung and semi spade were poor. However over the last 20 years or so thousands of boats have used them in all sorts of environments without problems.
