VicS
All the diagrams are in the link petehb gave in post #2
As said already the pump is on top of the gearcase. Pull that and all will be revealed.
Click on "details" for your year model and then on the diagrams for the various sections
The gearcase separates from the leg a cm or so above the anti-ventilation plate. See my post #12 above
If you have a long shaft model the look at the diag of the drive shaft housing to see how that is all fixed.
Impellers wear with use but also deteriorate with time and don't much like being scrunched up in the housing. But would not expect any trouble after only 6 years ... 16 maybe!
BtW when fitting the pump back together try to fold the impeller blades over so that they trail as it rotates(but its not essential as it'll soon sort itself out) just as you do with an inboard.
