Suzuki 6hp
Jonnibob
11 Jan 2017
Hello I have a 2008 Suzuki 6hp four stroke which I cannot get water to come out the pee hole . The pee hole is clear, I’ve fitted a new impeller and a new base gasket ! Any ideas
Jonnibob
11 Jan 2017
Also I’ve only tested it in water about 2inches over the cavitation plate .
VicS
13 Jul 2002
Are you sure that is deep enough to submerge the waterpump
A quick look at the engine diagrams suggests to me that water ought to be at well above the joint between the gear case and the drive shaft housing.
I hope you have not run the impeller dry !
Jonnibob
11 Jan 2017
Yea no the impeller is fine striped it and checked ,
The weather here is rubbish at the mo so I’ll try it s bit deeper soon thanks
jamie langstone
22 Dec 2013
when you say clear do you mean the pee hole it self as it could be a build up of salt blocking the cooling channels in the head.
a good way to make sure is to blow compressed air through the pee hole
C08
8 Feb 2013
In my experience you need the water a good 6" above the cavitation plate to get the water pumping.
Jonnibob
11 Jan 2017
8FA832CE-E283-47DD-80E4-61DE4DD2D0D3.jpgM
Me again im no mechanic but how does the water get to the pee hole ?
Blue line, it comes in from water pump goes over the head out the other side,how does it get from there to
yellow line to pee hole ? Pee hole red ?
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Just had this problem with my Suzuki 4 HP, which, AFAIK, is the same basic unit with a smaller carb.
As it was nearly ten years old, but virtually unused, I pulled the bottom off and fitted a new impeller. The removed one was as new.
When started, no water coming out. I prodded the pee hole with a fine wire and got a good spurt. As soon as the wire came out, no water! Poking about it was clear there was something acting as a valve in the outlet channel. Prodding moved it, allowing the water out, removing the prodder allowed the debris or whatever to block the hole.
I twisted a 1.5mm drill bit in the outlet pee hole for a few seconds. When examined, soft black stuff was found in the flutes of the drill bit. I prodded, poked, twisted the drill bit and poked curved wires in and out of the pee hole with it running in my dustbin full of water and it appeared to clear completely.
Used it on the tender, short-300 yards or so trip-and it slowed to a dribble.
I had prudently attatched a prodder to the kill cord. A quick prod and all normal.
So, my Suzuki had a softish bit of gubbins in the pee hole channel whick acted-and perhaps is still acting-as a one way valve.
Hopefully it will clear completely with more use.
I hope yours is as simple.
[2068]
19 Sep 2002
View attachment 77162M
You need to think in 3D - water comes in, circulates around the block, and (hopefully) mostly exits via the exhaust route, with some going via the tell-tale.
If not, could be blockage, poorly pump, head gasket issue, etc.
Firefly625
18 Mar 2009
Home=Surrey / Boat=Hamble
if the tell tail isn't working when running allowing the engine to run 5-7 seconds then switch off and re-start, do this at least 5 times.. maybe 10. Bet after the 5th time water will be coming out the tell tail....each time getting successfully more powerful.
if its not.. take it in for a service.
