westcoastgrind
Engine is a 2023 suzuki 2.5 with less than 20 hours on it. The idle is hanging pretty bad. It takes about a minute to come down from only a little bit of throttle.
I have cleaned the carb twice now; the second time with an ultrasonic cleaner. Carb never looked dirty, and jets looked clear. I also replaced all the carb gaskets, all the way to the cylinder block. Everything is torqued to spec.
I am confident the carb is clean, the idle speed is correct, and that there's no leaks from air intake to the block.
I have also played around with idle mixture screw. Richer makes idle hang worse, and leaner helps. I have heard that typically idle hang is due to air leak or lean condition, so this is confusing to me.
A suzuki tech briefly looked at it and was the one to tell me he suspected it was an air leak.
I'm really hoping to avoid spending hundreds of dollars to fix an engine that is brand new and should be warrantied. dealer is not being agreable and wont rouch it under warranty because messed with idle screw
What else could be causing my idle hang?
