Portofino
- engine anti-vibration rubbers (survey report says "Port engine, aft starboard anti-vibration mount was broken that a metal piece was welded instead. The other mountings of the engines were rusty, possibly the vibration rubbers were not in good condition.")?
Quote above from OP,s post
He,s written that from the survey , " report says " hence the confusion
To the OP just to be clear
MAN engines inc 6 cylinders R8 have an anti vibration damper on the end of the crank .
Engine mounts are not the same .
Thing is this a unbalance prop ( damage ) or and shaft will wreck the gearbox and poss stress out the " aft rear " engine mount ,
Other aspect of the report suggest missing bits on the stern-gear -is it the port side ?Maybe it's all been fixed ,if so why has the seller not said or got any papers parts bills for any works ?
Something has caused that mount to fracture it's not normal .
It's either bent / misaligned stern gear or crank damper issues ? Where are the bills to back up a repair ?
Considering Italy is awash with P's and P 46 for sale ,this one is throwing up too many questions -walk away IMHO
Also aside the buying process is real easy and the tax issue transparent in Italy .
Turkey is outside the EU I see potential paperwork hassle ,note i said potential .
