Wild Weasel
Active Member
Hello everyone,
I'm in the process of buying a P46 (2006) in the Med. Checked out the boat and looked clean enough to make an offer pending full survey. Agreed price and had survey done.
I now received the survey report and there are quite a few things that need to be taken care of. Question now is how to approach broker/seller and make sure they fix the items needed to be fixed before the transaction (or back out). What is reasonably the responsibility of the owner and what is considered wear and tear that I need to take care of once the transaction completes?
From the report I compiled a list that IMO is the responsibility of the owner, but considering this is my first boat would appreciate some validation or pointers before I go back to the broker.
I've asked the same to the surveyor and he says that: "The boat must be repaired as much as for her safety and seaworthiness before the transfer. It is long way you must not have problem on the sea. Problems of the engine and propulsion system have to be solved. Safety equipments (fire and bilge equipments, life raft, life buoys, life jackets) must be on boat as ready for use. Who will pay for what will pay is negotiation between buyer and seller."
Doesn't help the broker has been utterly useless in the process.
The list I compiled is as follows:
- the propeller shaft bearings (this has been confirmed by the owner as their responsibility)
- water under teak panel in the cockpit?
- fore sidescuttle of the galley needs to be fixed so it can close
- saloon entrance door fixed so it can close comfortably?
- rust on the engines (this has been confirmed by the owner as their responsibility) (sand and paint)
- periodical renewal of oil and filters (never done)?
- fuses of one of the control units sits outside of the case (need to be put back)?
- engine anti-vibration rubbers (survey report says "Port engine, aft starboard anti-vibration mount was broken that a metal piece was welded instead. The other mountings of the engines were rusty, possibly the vibration rubbers were not in good condition.")?
- propellers (survey report says "The propellers were needed to be repaired. At the blades end, bending and missing parts were surveyed")?
- missing part at the aft of the starboard propeller shaft bracket?
- generator fuel quick closing valves (survey report says "The fuel system was checked and found satisfactory except generator fuel quick closing valves was not working.")?
- electrical problem bow trust system (bow trust could not be tested didn't work because electrical problem)?
- main bilge pump / bilge alarm?
- deck washing pump (survey report says "The valve of the system in chain locker was out of order that has to be renewed maybe also the pump.")?
- fire extinguishers at each cabin need to be inspected and certified?
- submersible pump in the gray water tank/bilge pump?
- water strainer a/c?
- generator fuel transfer pump (fuel transfer pump was not working properly)?
- generator starter battery has to be fixed with a case?
- cooker/stove (left stove not working)?
- life-raft inspection?
On the bilges report says "There was water at front bilge and it was not salty. There was water at the engine room bilge and starboard side was oily, bilge was dirty. There was water at the back bilge and was salty. Eventually, nothing was seemed abnormal as constructional but all bilges were dirty."
Any advice much appreciated before I get back to the broker.
WW
WW
