SureStart conundrum
oldbilbo
17 Jan 2012
West country
Most of the MABs I've encountered have a spray-tin of SureStart adjacent to their ould engines. On querying, some experienced engineers insist use of that product causes the engine to 'become addicted' to the stuff, and recommend use of WD40 instead.
A skilled specialist in Haynes Motor Museum - the part that services classic and specialist cars - suggests that a recurring starting problem might well be due to a small air leak in the fuel supply, requiring that air to be purged through by 'churning' before diesel fuel gets through....
Can any erudite forumite explain the 'addiction' concept? Is WD40 a better product to use for assisting a start?
reginaldon
20 Feb 2004
kent
Air leak =- that was the problem with my Yam 5, my grandson found it!
ufans
26 May 2015
“addiction” is caused by the lack of lubricant in the spray (used to be ether, not sure on modern equivalents).
Apart from combustion it washes lubricant from the bores, so if used excessively over time leads to reduction in compression this can lead to being unable to start normally without its use.
It was a common problem in trucks prior to improved cold start devices.
scottie
14 Nov 2001
scotland
The active element is normally an ether type gas which has 2 effects
The first is that it explodes at far lower temp and is not subject to accurate timing and other is that it removes the lubricant from the engine bores
The addiction theory is based on the increasing bore wear and thus lack of compression resulting in the need for additive
VicS
13 Jul 2002
The addiction concept is the result of owners not fixing the real cause of poor starting. As time goes by the original problem gets worse and the engine wont ever start without the use of a starting fluid.
WD40 is mosstly white spirit, or similar. If the auto ignition temperature of white spirit is loer than that of diesel oil then it will help. Traditional starting fluids are ether based. That has a much lwer autoigniion temperature.
Wd40 at least contains a little light oil which may help overcome the lack of lubrication in ether based products.
Easy start is bad in compression ignition engines because you have no control over the ignition timing, as you do with spark ignition. This can result in serious mechanical damage if the ignition occurs too early. If Skpper stu comes by he will tell you how many thousands of diesel engines around the world he has had to rebuild as a result of this
Boo2
13 Jan 2010
Presumebly WD40 would have the same effect re washing lubricants off the bores ?
Boo2
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
As many industrial engines used ether starting as standard it can't be that harmful. As said find the source of the trouble and rectify. Better to use the stuff to start the engine when needed than to not be able to start it at all!
ghostlymoron
9 Apr 2005
Shropshire
I think the problem with easystart (surestart is a sort of marine AA) is that an engine that is marginal in the first place has the symptoms magnified and disguised by the easystart until it will NEVER start without it. If you have to resort to it, you should only do it once and then when safely home, find and rectify the faults.
sarabande
6 May 2005
have you tried unscrewing the bleed nut of the injector pump?
If air bubbles come out with diesel, you have confirmation of your thesis. The hard bit is tracking the source of the air intake.
Len Ingalls
6 Dec 2014
N.B.,Canada
If bleeding air doesn't cure hard starting,check compression. Probably needs valve grinding. / Len
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
Put talcum powder on the bleed screw, all the joints in the fuel line and any connections in the filters plus anything else you think could leak. Diesel will go through a microscopic holes and draw air in. Run the engine for half an hour and check the talcum power. Usually the revs go up and down if the is a significant diesel leak.
Alpha22
22 Sep 2003
Cambridgeshire
Another reason WD-40, or for that matter ANY aerosol can works, is that the propellant used is quite often butane gas. Hair spray, fly spray and even deodorant are all highly flammable due to the butane propellant. I suspect far more butane gets sucked into the cylinder than the actual oil.
Even "canned air" favoured by photographers for cleaning dust is largely butane. As one technician at work found out at the cost of his eyebrows and fringe. He was cleaning the optics of a slide projector whilst it was turned on and hot. The fireball was large and very impressive..... thankfully also very short lived.
